I'm using 4 P3A's (home made PCB's) in an active configuration and I have serious ground loop problems due to active filters being in a separate box. I got hold of a bunch of BeyerDynamic input 10k transformers and intend to have those in my next P3A layout. My question is, how do I do this? I'd like to remove the input DC-blocking cap. I've tried just removing the cap, connecting the transformer secondary windings from input to ground but this the P3A started to distort. Any inputs or links to other similar input transformer coupled amp would be greatly appreciated. /Jesper |
#2 |
#3 |
Yes, that works offcause.
But I'd like to remove the 4,7uF input cap. When I do so I get distortion. /Jesper |
#4 | |
there are two possibilities: First, P3a isn't very happy with DC coupled input. Second, the transformer is saturated with DC current that flows thru the secondary winding from GND to the input transistor's base. Best keep the input cap, IMO. Regards, Milan |
#5 | |
#6 |
What if you placed the secondary between the base resistor and ground?
#7 |
I've tried tying the secondary to the base of Q1, both directly and by via the 2k2 base resistor, neither worked at all.
However, I've not made any thorough testing. I'll bring a oscilloscope home tonight to see what's really going on. /Jesper |
#8 |
"BeyerDynamic input 10k transformers "
Are those rated for line level, or just mic level? |
#9 | |
Beyerdynamic 10k linelevel transfomer |
#10 | |
When you connected the transformer coil from the 2k2 resistor to ground, as far as DC bias, you just shorted out the 22K resistor to ground. DC resistance of the coil is very low. 10K refers to the impeadence at 1KHz. Measure the resistance with an Ohmmeter and you will see what I mean. What I ment before is to break the circuit between the 22K (R2) and ground. Place the secondary coil there so that it is in series with the 22K (R2) and ground. This should not adjust the DC offset too much---if you have DC offset adjustment. You may need to add a loading resistor to the secondary, then again maybe not....experiment and see. I have made circuits using this method and they are very stable as far as DC offset and drift. |
| What to do with a 5k output transfomer? | Switch | Tubes / Valves | 17 | 23rd July 2008 08:12 PM |
| transfomer for monitor - 602M | jfrago | Vendor's Bazaar | 0 | 3rd August 2007 04:53 AM |
| Beyerdynamic 10k linelevel transfomer | jesper | Parts | 5 | 26th October 2004 07:04 AM |
| Think this is worth $60? (transfomer) | Hybrid fourdoor | Swap Meet | 5 | 22nd June 2004 10:56 AM |
| Transfomer Too hot on my AudioNote 300B kit one | audionote | Tubes / Valves | 7 | 6th November 2003 11:20 AM |
| Page generated in 0.10221 seconds (82.26% PHP - 17.74% MySQL) with 11 queries |
