and if so how do they make the auto audio 1 farad cap so small?
#2 |
Small ? I don't think so... And they have only ~16volts
#3 |
Roughly put:
cap-size ~ capacitance x voltage handling the size of the cap is porportional to it's capacitance and voltage handling. So, if you only need a small amount of voltage handling, you can make the capacitance fairly high in a pretty small size. Such as those 1F 5v caps that are the size of a few poker chips stacked. Those 1F car caps are not that small... -- Danny |
#4 |
the caps are usually rated at 20-25V DC,
I don't think they are small considering the size and voltage rating. for size comparisons, I usually multiply the voltage and capacitance ratings. (pointless but it makes some sense. so if the cap is 20v X 1000000uF, it would be approximately the same size as 100V 200000uF. |
#5 |
I have 4 15,000uf caps and combined they are larger in physical size then a 1 farad cap. So it is the voltage rating that makes the difference.
#6 | |
capasitor size ~ capacitance x (voltage) ^2 |
#7 |
RTFM
Ripe Tomatoe From Molokai Right Turn For Missouri Roam The Frontier Miss Rough Tough Female Masseuse Right Tuthe Front Mister Real Tough Farm Maiden Read That First Mommie Real Transistors From Motorola nah, can't get it. ![]() Prosit
#8 |
diyAudio Editor
Read The !@#$ Manual?
#9 |
By jove, I think you've got it.
----------------------------------------------- Kilowattski |
#10 |
Not Run to French Morocco?
| 25v 40 micro farad capacitors | conor4 | Parts | 12 | 27th June 2008 04:20 PM |
| 1 farad power cap | odysseybmx414 | Chip Amps | 15 | 26th March 2005 11:12 PM |
| 1 Farad capacitors for car audio | ssanmor | Parts | 12 | 16th October 2002 10:14 AM |
| .5+ Farad Capacitors | nitropowered | Parts | 0 | 14th July 2002 01:47 AM |
| Page generated in 0.09482 seconds (77.75% PHP - 22.25% MySQL) with 10 queries |
