Hi All,
This is my first post, so I hope it works ok! While reading this thread: much less crazy idea I noticed the talk of generating floating grounds with big resistors, which reminded of the scheme that Quad used for their 306 amplifer (amongst others, I'm sure). By putting 2 smoothing caps in series, the voltage at their midpoint is roughly equal to half the total supply voltage. To ensure that it remains close to this point, two transistors are used to steer the point to the required voltage. This then forms the signal ground for the whole amplifier. This arrangement offers DC protection for the loudspeaker - if one of the output devices saturates. the midpoint will be allowed to rise to the appropriate tail, thus avoiding damage to the speaker. The only drawback of this is both capacitors must be rated to the total supply voltage (unlike a conventional split supply, of course) Hopefully, this might be useful if you happen to have a large mains transformer with a single winding...? Apologies if everyone already knows this! BTW, click here for the complete Quad 306 schematic |
#2 |
The problem is that this is the same as a capacitor coupled speaker, only the capacitors are placed differently. All the speaker current still have to go through the capacitors and they need to be highly ripple tolerant.
But it is an interesting schematic. I didn't get the quad link to work, though. /Marcus |
#3 |
Sorry about that!
Try this instead The Quad306 link is towards the end of the list... I wondered about the sonics, as it does appear to be equivelent to a simple series capacitor at a first glance. But, as the signal is referenced to this floating ground, I guess that feedback should help... |
| simple HV rail splitter/floating ground - would this work? | Rodeodave | Power Supplies | 3 | 20th July 2008 04:12 PM |
| Floating ground power supply | Theodore Julie | Power Supplies | 8 | 11th June 2007 10:54 PM |
| Floating Ground Adapter? | geek883 | Car Audio | 2 | 2nd April 2006 07:26 AM |
| car preamp with artificial earth(ESP) | sagarverma | Car Audio | 23 | 8th November 2005 04:31 PM |
| Artificial Harmonics | guitargully | Instruments and Amps | 1 | 15th April 2004 06:53 AM |
| Page generated in 0.07475 seconds (69.98% PHP - 30.02% MySQL) with 11 queries |
