#11 |
Use TPA 6120A in bridge mode. Although this circuit is not working in class A, give you much more lower distortion than some Zen.
#12 |
I will certanly sound dump but I got to ask what is TPA 6120 A ?
#13 |
It is new headphone " superamp ", made by Texas Instruments, with high current capability, which give output power 1-2 W.
#14 |
At these relatively low voltage levels (for the supply), losses in Vbe, resistors, etc will be significant. Remember, that for most designs, output voltage vill be somewhat lower than the supply voltage for the gain/driver stage.
To optimize this, my bet would be to use a chip amp, despite it not being class A, or to use a rail-to-rail output op-amp for the gain stage, and let it drive a Vbias and output stage. At these levels, there may not be a need for a "real" output stage - a driver stage with TO-220 transistors should be enough as output. Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good. |
#15 |
Properly designed output stage based on "diamond buffer" structure and biased to class A will swing close to supply rails.
#16 | |
Electrons are yellow and more is better!
It's an extremely good current feedback amp which Texas thinks is good for driving headphones http://www.diyaudio.com/forums/showt...138#post486138 You could also make an amp similar the QRV-06 but with hole mounted parts like in the QRV-03 . Both my designs have "high-end" diamond buffers. SonnyA has made a simliar power amp also http://mirand.dk
/Per-Anders (my first name) or P-A as my friends call me |
| 10-20 Watts Super Single Ended Class A | umut1001 | Solid State | 15 | 10th September 2008 07:04 PM |
| Another class-D amp,2x50 watts! | hsu | Class D | 13 | 2nd November 2007 04:02 AM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| detailed examination of 5 watts class a amplifier circuit | renjiish | Solid State | 2 | 5th December 2004 11:11 PM |
| Class A 45 watts integrated | lpd | Swap Meet | 1 | 28th November 2004 12:23 PM |
| Page generated in 0.08499 seconds (75.06% PHP - 24.94% MySQL) with 10 queries |
