Power amp under development - Page 390 - diyAudio
Old 24th July 2014, 02:54 PM   #3891
mrlord is offline mrlord  Italy
mrlord's Avatar
Send a message via Skype™ to mrlord
You have some idea, Andrews?
Best regards
Mrlord.
Old 24th July 2014, 03:09 PM   #3892
Gate of T13 to Ground seems wrong.
Does a cap from base to collector of the driver help?
I hope some others will come in.
I am not any good at AC problems.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th July 2014, 05:37 PM   #3893
mrlord's Avatar
There are all in holidays....!!!!
Best regards
Mrlord.
Old 24th July 2014, 06:49 PM   #3894
Vostro is offline Vostro  South Africa
Vostro's Avatar
I'm noob, but I would try a 22pf from base of T2 to base of T5, this is easy to try, don't have to change anything on board.
If prob on output, did you use resistor values on driver bases shown on drawing, maybe increase to 150R, also same for gate resistors on outputs.
Anyway that's what I would play with at first, remembering I'm only experimenter, not expert
Old 25th July 2014, 08:10 AM   #3895
mrlord's Avatar
Thank for reply. @ Vostro: what mean "prob" ? Im not perfect in english, sorry.....
Another question: 22 pF instead C3 (330 pF) or another cap in parallel to R6 - C3?
Best regards
Mrlord.
Old 25th July 2014, 02:30 PM   #3896
use Quasi ACRTK schematic this circuit have perfect square wave.
Nmos sound is not so good like many Class AB Designs, I made Nmos before and have changed to Class D, never want go back to Class AB.
Class D is big improvement in Sound with low heat compare to class AB
Old 25th July 2014, 04:04 PM   #3897
mrlord's Avatar
I have tryed to put 39nF cap from base to collector of the driver (T11), as how said Andrew ... catastrofic result: sine wave orrible!!!!
Also I tryed 22pF from base of T2 to base of T5, as how said Vostro: nothing change and the oscillation remain the same.
Best regards
Mrlord.
Old 25th July 2014, 04:07 PM   #3898
mrlord's Avatar
I ave already made 2 pcb for NMOS....
I tink so...
Maybe in the future.... in this time my amp MUST work well!
Best regards
Mrlord.
Old 25th July 2014, 07:35 PM   #3899
The amp can not work well because you need about + 10 V / bootstrap to drive negative rail for full rail swing / perefct sine wave without oscillation. Thats why quasi make Acrtk Nmos Amp. This amp have + 10 V to fix this problem, check the schematic you will see
Class D work same, using 2 N Channel Mosfets and have +12 V Bias / Bootstrap for drive negative Mosfets
Old 25th July 2014, 07:54 PM   #3900
Plenty of the Nmos 350 original mk1 amplifiers worked 100 %. I don't know if the mk 2 worked.
Jan
Copyright 1999-2017 diyAudio
