Power amp under development - Page 369 - diyAudio
Old 24th February 2011, 10:56 AM   #3681
andrewlebon's Avatar
Default output power
hi nmos
greetings with 6 pairs of IRF460 and 90 volts rail what should power
output of amp be
thanking you
andrew lebon
Old 24th February 2011, 11:31 AM   #3682
AndrewT is online now AndrewT  Scotland
output of amp be
I have told this before and I have shown you the method to work this out.
How many times do you expect Members to respond repeatedly to the same questions?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th February 2011, 12:15 PM   #3683
Originally Posted by NMOS View Post
Hi use IRFP460 easier to get by supplier and high Voltage you can push harder
IN my design IRFP460 is working
can u post your working nmos350 single side pcb layout.
Old 24th February 2011, 09:47 PM   #3684
TonyTecson's Avatar
output of amp be?
300 watts into 8 ohms is possible......
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 24th February 2011, 11:19 PM   #3685
Default thank you
dear tony
greetings thank you for your reply i really appreceiate it
thanking you
andrew lebon
Old 25th February 2011, 02:42 AM   #3686
quasi is offline quasi  Australia
quasi's Avatar
100v rails on Nmos350/500? How hot do the 2nd and 3rd stages get? Still nice to see the amps grow. Nice work NMOS.
Old 18th March 2011, 05:49 PM   #3687
can anybody share clipping curcuit of nmos200 247.
Old 18th March 2011, 07:37 PM   #3688
maxente is offline maxente  Romania
maxente's Avatar
hey quasi and other diy'ers a few month's a go i build NMOS200
i found a thread in a romanian forum posted by alex mm
after browsing the net i found the original tread
WOOOWWW maaan there a over 3600 posts
what can i say this amplifier realy BLOW my speakers
the rails of NMOS200 is +/-32Vcc but the sound is so clear
now i wanna build NMOS350 version whit the rail of +/-85v
thank you Quasi for sharing this nice amp
sorry for my poor english
here some pics
Old 18th March 2011, 08:40 PM   #3689
here some pics
for the output which transistor u use and thermal track transistor.
how do u adjust the bias?
can u share the romanian web u find.
can u share ur pcb layout.
Old 18th March 2011, 09:49 PM   #3690
maxente's Avatar
i use irfp240 for output stage and bd139 for termal track
for adjusting bias i use a normal digital ampermeter in series with +v rail
(i know it was better to set bias with 100ohm /5w and 10ohm resistor as quasi sugested in his web site http://sites.google.com/site/quasisdiyaudiosite/home)
first befor powering up i set vr2 cursor to R13 i use a jumper in input
then powering up
i set ampermeter to 250mA and then adjust vr2 to get 50mA
after that adjust offset to les 10mV (i don't known exact value because it was a few month ago)
the amp is still working even whit low v rail of +/-32v
i use it with 8 ohm speakers and sensitivity (1w/1m): 90 dB
and i think i got about of 50w because of low v rail
but it sounds very loud and clear to (i think it's because of the sensitivity of the speaker)
romanian forum is Forumul electronistilor • Prima pagin?
Copyright 1999-2017 diyAudio
