Power amp under development
Old 4th December 2005, 12:30 PM   #211
quasi is offline quasi  Australia
quasi's Avatar
Default 12 volts ?
Yes you can use 12 volts. The relay will take a little longer to switch. If this makes you unhappy you can reduce the value of the 330k resistor or the 470uF capacitor.
Cheers
Old 4th December 2005, 12:54 PM   #212
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Default Replay of Replay
Thanks Quasy, !, and ofcourse what happened with soft start.Because is too many caps.
Old 4th December 2005, 05:09 PM   #213
pejinm is offline pejinm  Serbia
pejinm's Avatar
You can use this schematic for soft start...
POZDRAV
Old 4th December 2005, 05:11 PM   #214
pejinm's Avatar
Here is the PCB...
Old 5th December 2005, 07:10 AM   #215
ravirat4u is offline ravirat4u  India
Caution AC!
Old 7th December 2005, 11:01 AM   #216
quasi's Avatar
Originally posted by ravirat4u
Caution AC!
This is the slow turn-on cct that I used for the amp. It uses a seperate small transformer to power the delay cct. It's simple (too simple?) and also provides a DC supply for other uses i.e. Fan, LEDs etc.
Cheers
Old 7th December 2005, 11:02 AM   #217
quasi's Avatar
And here's the layout .....
Old 7th December 2005, 11:07 AM   #218
quasi's Avatar
And the tracks ....
That's it. Using all this you should be able to build an amp that is similar to the one I completed.
The amp has just come back from another Hi-Fi nuts house (returned reluctantly after a month) and seems to be going strong.
Good Luck
Old 7th December 2005, 11:57 AM   #219
stoN_Cold's Avatar
Default 2xreplay of replay
Nice job, BUT schematic & part list is mising!
Old 7th December 2005, 12:02 PM   #220
quasi's Avatar
Default Re: 2xreplay of replay
can't you see the picture in post #216?
Power amp under developmentHide this!Advertise here!
Copyright ©1999-2017 diyAudio
