Power amp under development
Old 18th December 2004, 01:41 PM   #131
demogorgon is offline demogorgon  Norway
demogorgon's Avatar
Send a message via MSN to demogorgon
sounds grate!
Will there be a post gathering all info of the amp when you'v buildt and tested both boards?
regards
marius
Old 20th December 2004, 08:10 PM   #132
Nexus is offline Nexus  Netherlands
Default splif
Hello All,
about a year ago, I build the splif topology as added in the word file.
My opinion about it:
First I build an amplifier with just one pair of BJT's driving the speaker, however the damping was very low and so the bass tones were not "tight"". So I build another with 10 parallel pairs in the output. Attached the schematic.
I listened to it for about half a year, and didnot like the sound anymore, the amplifier simply is not linear, and this is audible.
instruments like a saxophone sound good, but the rest of the instruments simply do not sound natural.
I want to state that this is my personal opinion, maybe someone else thinks different about this.
Best Regards:
Nexus
Old 27th December 2004, 10:15 AM   #133
quasi is offline quasi  Australia
quasi's Avatar
Default Final Schematic;
This is the final schematic of the amp module. Two modules have been built and it is time to assemble the complete amp.
The major changes to the design are;
1. The split supplies have been removed and common rails feed the whole amp.
2. The cascode transistors have been removed from the input stage and replaced with a current mirror (Q4 & Q5). This change has been made to ensure symetrical current flows through Q2 & Q3.
3. Removing the cascode stage has required high voltage transistors for Q2 & Q3. I have settled on 2SC1845. These are low noise transistors with Vce of 120 volts.
4. Some resistor and capacitor values have been changed to try and achieve a balance of noise, distortion and thermal peformance.
There are other improvements that can be made to this schematic and these will be implemented at another time. But this is the schematic that will be put to service in the completed amplifier.
Many forum contributors will see their suggestions in this schematic and to you I say thankyou.
Cheers
Old 31st December 2004, 04:29 AM   #134
quasi's Avatar
Default Proposed layout;
This will be the layout of the amplifier. There is some rooom leftover for further additions (clipping indicator, rail monitors fault conditions etc.)
Now I have to make the case.
Comments welcome of course.
Cheers
Old 31st December 2004, 06:22 AM   #135
rajeev luthra is offline rajeev luthra  India
GOOD JOB QUASI
RL
Old 31st December 2004, 05:33 PM   #136
hienrich is offline hienrich  Philippines
hienrich's Avatar
quasi
REAL GOOD JOB. I REALLY ADMIRE YOUR WORK. FROM THE VERY
BEGINNING TIL THE FINAL DESIGN
WHAT A NICE JOB.
HIENRICH
Old 1st January 2005, 01:15 AM   #137
quasi's Avatar
Default Thanks hienrich, demogorgon & rajeev;
Thanks heaps for your compliments. This has taken a long time but it's getting closer to the end.
When it is finished I will post all the ccts and layouts for anyone who is interested.
During this exercise I have found areas that can be improved but the board layouts don't allow this easily. Even so the amp as it is performs very well, is very quiet and clean.
I will attempt some specifications when the case is finished and all the components are fixed.
The best part about this amp is that it has been built using mostly second hand parts found in junked electronics (power supplies etc.) or parts recycled from other projects. To date the whole project has cost under $100 AUS ($75US) and I have everything I need for the case.
Thanks once again for your kind thoughts.
Cheers & Happy New Year
Old 1st January 2005, 05:22 AM   #138
hienrich's Avatar
quasi,
IM SO INTERESTED WITH YOUR WORK. I'LL JUST WAIT FOR FURTHER DEVELOPMENTS . I HOPE YOU'LL POST IT WITH EVERY DETAIL.
HIENRICH
Old 1st January 2005, 01:49 PM   #139
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
heinrich,
No need to SHOUT
(Using capitals on the internet in email or forums is counted as bad practice and is taken as shouting)
Old 1st January 2005, 04:25 PM   #140
Workhorse is offline Workhorse
Workhorse's Avatar
Arrow Happy New Year
Hi QUASI COMPLEMENTARY,
You have done a great and fantastic JOB,
cheers,
Kanwar
Power amp under developmentHide this!Advertise here!
