amp with single input can't amplify pulse signal,please help me
Old 23rd October 2004, 03:33 PM   #1
thanh is offline thanh  Viet Nam
thanh's Avatar
Send a message via Yahoo to thanh
Default amp with single input can't amplify pulse signal,please help me
hi all! this is my circuit and sim
Justice for Victims of Agent Orange
http://www.petitiononline.com/AOVN/Thank all of you!
Old 23rd October 2004, 05:30 PM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi thanh !
Hmm, what exactly is your problem ?
The overshooting ? Or the uncentered signal ?
The uncentered signal is an issue with sim. Remove temporaly the
inputcouplingcap and the signal is centered. The amplitude seems
correct. While the sim is biasing the circuit, the inputcap gets charged
with 70mv.
The overshooting is an issue with correctly adjusting feedbackcaps.
Ooops, i detected a FATAL problem in your circuit, NEVER take signal
for feedback after outputfilter/coil. This amp will not be very stable.
Take feedback at L3:1 !
A suggestion, try adding RE of 120ohm to the vas-transistor, it might
reduce openloopgain without increasing thd...
Mike
Old 26th October 2004, 02:56 PM   #3
thanh's Avatar
thank mikeb very much! I will try to do like your comments
amp with single input can't amplify pulse signal,please help meHide this!Advertise here!
weak input signal to amplify pra3718 Chip Amps 2 14th January 2009 03:29 PM
LT SwCADIII pulse signal from DAC, how? aparatusonitus Digital Source 2 18th July 2005 05:24 PM
Creating a differential signal from a single-ended signal for bridged amps Peter Daniel Chip Amps 45 8th November 2004 01:47 PM
Can amplification based ta3020 amplify direct current signal? green3002 Class D 0 14th October 2004 07:01 AM
Amplify weak signal to stronger... Mikka Solid State 18 8th June 2003 04:12 AM
Copyright ©1999-2017 diyAudio
