transformers? - Page 2 - diyAudio
Old 22nd October 2004, 07:24 AM   #11
Carondimonio's Avatar
Ok, maybe I wasn' t clear enough, might be my bad English?
Why 0.25 Hz?????
Old 22nd October 2004, 07:24 AM   #12
quasi is offline quasi  Australia
quasi's Avatar
Exactly Carondimonio, you wouldn't. But this site boasts 0.25hz to 100khz + at +/- 3db through a coupling transformer.
As soon as read ridiculous statements like that I ...well I ... well I just sort of chuckle and wish the people with too much money, happiness and health.
Cheers
Old 22nd October 2004, 07:29 AM   #13
djk is offline djk
djk's Avatar
Never heard of Jeff Rowland either.
"the Rowland Model 2 is unusual in having transformers in the signal path on the input side. "
" From the reviewer’s perspective, the best situation is one in which the component sounds so good right off the bat that there’s little or no need for tweaking or substitution of components. This was the case with the Rowland Model 2. "
" my immediate impression was of a level of detail and transparency that went beyond anything I had heard previously in my system. It was an impression that was to persist throughout the extended evaluation period. "
"Throughout the entire range, but especially in the highs, the Model 2 had stunning transparency, providing resolution of detail but adding little sound of its own. In fact, the aspect of the Model 2's performance that impressed me the most was its resolution. "
http://www.jeffrowland.com/review34a.htm
"Super-wide passband. Like most any high-end audio amplifying stages, these transformers have a few extra octaves of frequency response at each end. That’s 0.5Hz to 180KHz! "
http://www.jeffrowland.com/transfor.htm
Old 22nd October 2004, 07:44 AM   #14
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Low Frequency -3dB point
Originally posted by quasi
Well, you obviously never heard of Steve Eddy......
This is a commercial marketing site not a research site.
With respect, I don't pay any attention to marketers. (in audio anyway).
Still I'd be interested to see how you can get get 0.25 hz through a transformer that is smaller than my car ...There is probably a lot of other stuff in there (at least I hope there is).
Actually the -3dB point IS at about 0.25Hz in the frequency response graph on Steve Eddy's site. If you still do not believe me you can check the datasheet of the Jensen JT-11P-1 transformer used in the design here:
http://www.jensen-transformers.com/datashts/11p1.pdf
Old 22nd October 2004, 07:48 AM   #15
quasi's Avatar
Hmm ...nothing here about interstage coupling.
I need to see some circuits to verify the claims ....this is after all another marketing site similar to many of the HIFI magazines which frankly overuse scientific terms to confuse basic concepts.
I note that some input devices like my very expensive AKG microphone of yesteryear has transformer coupling built in ...but this is microvolts stuff and designed in part to compensate for the active element. This mike goes down to 20hz @ -2db (it is an excellent microphone after all).
But 0.5 hz or 0.25 hz. I hold; at $6K US, there's gotta be other stuff around these transformers (or at least I hope there is).
Old 22nd October 2004, 07:52 AM   #16
quasi's Avatar
Did you read the little lable on the graph. Hope this definition of
augment helps.
\Aug*ment"\, v. t. [imp. & p. p. Augmented; p. pr. & vb. n. Augmenting.] [L. augmentare, fr. augmentum an increase, fr. augere to increase; perh. akin to Gr. ?, ?, E. wax, v., and eke, v.: cf. F. augmenter.] 1. To enlarge or increase in size, amount, or degree; to swell; to make bigger; as, to augment an army by re["e]forcements; rain augments a stream; impatience augments an evil.
Sorry this chart is irrelevant.
Old 22nd October 2004, 07:58 AM   #17
Banned
Cool I Rest my Case
I rest my case and leave it to Steve Eddy to elaborate.
Old 22nd October 2004, 08:10 AM   #18
quasi's Avatar
Aaaah. Thanks I now see the area of confusion. This transformer is specifically designed for balanced inputs ( 3 wires).
This is a completely different kettle of fish and has to do with inputs of balanced sources.
This thread is about using transformers for interstage coupling within pre-amps and amps. Eg; after the input stage and say the driver stage.
Old 23rd October 2004, 07:41 PM   #19
This is a stupid question, but here goes.
If the transformer is driving an impeadence that is inversly proportional to frequency, by matching the semilog curves to that of the transformer frequency responce(& impeadence), can the lower freq. responce be enhanced?
Or will this just screw up the phase of the output because of capacitance loading?
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
FS: Transformers alexcd Swap Meet 0 19th November 2008 08:34 PM
WTB : Transformers korben69 Swap Meet 1 27th June 2008 06:05 PM
my first amp (transformers???) fitchmicah Chip Amps 5 7th January 2007 07:26 PM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
Copyright ©1999-2017 diyAudio
