My Amp Design - Page 4 - diyAudio
Old 8th July 2002, 08:12 PM   #31
dshortt9's Avatar
Yes, you are correct, the open loop gain increases. What concerns me is having enough current to drive the outputs. They need about 50ma. for 5 amps out. This could be possible, as you say the input stage is not loaded by the 47R. I like it. Jens, I have not learned spice. Could you simulate this and see if it works? As far as bias stability, that is why I originally used small lateral mosfets instead of BC546, 556 as the input devices. If mounted with the output devices they have a negative tempco that would help stabilize the outputs, also a higher input impedance. 2SK216 and 2SJ79. See the first schematic in this thread.
Old 8th July 2002, 08:15 PM   #32
dshortt9's Avatar
I see I used IRF 610, 9610. My first thought was to use the K216, J79. They may be better.
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 06:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 03:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 03:56 PM
Copyright 1999-2017 diyAudio
