Old 18th October 2004, 12:02 PM   #1
jackinnj's Avatar
Default Splitting a supply
A circuit similar to this appeared in the most recent issue of AudioXpress ("MaxxBass Subwoofer") for splitting a wallwart supply into regulated +/- 5VDC -- this one won't oscillate!
Old 18th October 2004, 06:15 PM   #2
Steven is offline Steven  Netherlands
Steven's Avatar
Default Re: Splitting a supply
Originally posted by jackinnj
...this one won't oscillate!
But it won't work either. Your biasing is wrong, trying to force the opamp output to a negative voltage compared to the non-inverting input, which is at the negative supply rail of the opamp.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 18th October 2004, 06:58 PM   #3
jackinnj's Avatar
Default Re: Re: Splitting a supply
Steven
I flipped the OPAMP (vertically) by mistake -- mea culpa -- incidentally, the schematic is also on National Semi's website --
Old 18th October 2004, 07:27 PM   #4
jackinnj's Avatar
here's another go:
Old 19th October 2004, 08:36 AM   #5
djk is offline djk
djk's Avatar
Radio Shack sells several wall warts that are AC, I bought one the other day to replace one in a JBL BX63 electronic crossover.
Half wave rectify it for both supplies, then regulate it.
Old 19th October 2004, 08:37 AM   #6
darkfenriz's Avatar
doesn't it multiply the input offset voltage of the opamp by 15x
with the regulated voltage that small may be noticable...
am I right??
Old 19th October 2004, 12:51 PM   #7
jackinnj's Avatar
I have used an AC wall wart from a Sony answering machine -- you use a voltage doubler -- the ground is the junction of the two capacitors which are attached to the AC source.
Old 18th October 2006, 08:36 AM   #8
AndrewT is online now AndrewT  Scotland
what's the lowest supply voltage this circuit can accept?
output=10Vdc
Min input =? when loaded.
regards Andrew T.
Splitting up power supply inductance boywonder Tubes / Valves 3 9th February 2009 10:00 PM
Pre-Out Splitting Bigred Solid State 15 13th July 2007 06:27 PM
Splitting up the Power Amp spuloo Tubes / Valves 1 30th June 2007 03:26 PM
supply-splitting: TLE2426 alternatives? Dominique Power Supplies 7 28th February 2007 05:57 AM
Mic Splitting Transformers Mikeym Parts 1 18th August 2004 08:09 AM
Page generated in 0.08579 seconds (77.40% PHP - 22.60% MySQL) with 10 queries
