much less crazy idea - Page 2 - diyAudio
Old 27th June 2002, 02:13 PM   #11
e96mlo is offline e96mlo  Sweden
Pspice is a simulation software so if simulating is what you want to do it might be a good choice.
If you want to do PCB layouts then Eagle is a great and cheap choice. You draw your schematic and then you convert to PCB. Can be downloaded from their homepage www.cadsoft.de.
Recomended!
/Marcus
Old 27th June 2002, 02:25 PM   #12
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Thanks!
Old 27th June 2002, 03:53 PM   #13
Duo's Avatar
Here is the proper diagram for my amplifier.
Old 27th June 2002, 04:08 PM   #14
It wouldn't sound very good (if at all) since you have connected the base of the VAS transistor to negative supply.
I still think you should study the diff stage more and make some improvements.
/Marcus
Old 27th June 2002, 04:10 PM   #15
sonnya is offline sonnya  Denmark
sonnya's Avatar
I do not think that 2n3906 likes your +/-60V!!!
Sonny
Old 27th June 2002, 04:21 PM   #16
Nope. Neither does the BD139/140. At least not if you want to be on the safe side. The O/P devices will manage though.
You need at least a 120 V collector-emitter rating.
/Marcus
Old 27th June 2002, 04:23 PM   #17
Duo's Avatar
Hmmm, as far as I remember in some esp schematics, the VAS was grounded at the emitter and also, they used a 2n3906 setup on 55 volts, which isn't far off of mine...
EDIT, ooops, I see that my diagram does show a base tied to ground, when I actually intended for it to go to a 1k pot on the long tailed pair.... Darn Gotta fix that quick no wonder the simulator didn't like it!
Old 27th June 2002, 04:25 PM   #18
Duo's Avatar
and the BD139/140 are rated at 150 vce
Old 27th June 2002, 04:33 PM   #19
Duo's Avatar
in Rod Elliot's projecto of the 300w sub amp, he has a supply rail to rail of 110 volts and uses bc546 transistors rated at 40vce
Old 27th June 2002, 04:34 PM   #20
Geoff is offline Geoff  United Kingdom
Duo
I don't know your source of information, but the datasheets from Philips, Fairchild and ONSemi all quote a Vceo maximum of 80V.
Geoff
Crazy idea ak_47_boy Digital Source 2 7th February 2009 06:38 AM
Crazy plate amp idea... mazeroth Solid State 13 8th January 2005 07:20 PM
Crazy idea ! - thyristor amp Nysan Solid State 6 15th April 2004 02:10 PM
crazy idea... mekanoplastik Everything Else 12 6th January 2003 01:28 AM
Copyright 1999-2017 diyAudio
