Old 16th October 2004, 03:18 PM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Send a message via MSN to lykkedk
Default Simple PSU for RIAA / m-magnet
Hi i know, this is a odd. quistion, but is it possible to build a simple PSU for my Vellman RIAA :
RIAA stereo pre-amplifier for md pick-ups. Low noise.
Specifications
* supply voltage: 10 -30VDC / 5mA regulated
* gain (1kHz): 35dB
* input signal: 5 - 10mV
* input impedance: 47Kohm
* PCB dimensions: 44 x 65mm (1.7" x 2.6")
I have this transformer : PRI --> 230VAC (Denmark) SEC --> 13Vac - 0Vac - 0Vac - 18Vac
I have some nice Diode recit.... and some dIfferent's CAP's eg.. 2200uF 35V .. 470uF 25V, But unfortunatly only one of each ... I know it's a odd quistion, but maybe some have tried this..
Thanks in advance!
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp.
Simple MM only RIAA preamp x-pro Analogue Source 59 13th January 2008 03:15 AM
Needs simple RIAA pre-amp parmar664 Analogue Source 2 30th March 2007 10:29 PM
GC/RIAA (simple) preamplifer veteran Chip Amps 22 13th June 2006 08:31 PM
Another Simple RIAA preamp ? CheffDeGaar Analogue Source 7 10th February 2004 10:34 AM
Simple RIAA amp from c't magazine lohk Analogue Source 46 23rd January 2003 08:44 PM
Page generated in 0.06549 seconds (67.19% PHP - 32.81% MySQL) with 10 queries
