Old 16th October 2004, 01:02 PM   #1
viki is offline viki  Portugal
Default 100W Amplifier Shematic and PCB
I am mounting this amplifier
http://www.diyaudio.com/forums/showt...769#post373769
and the PCB
http://www.diyaudio.com/forums/showt...332#post365332
Taht is suposed to get 100W RMS 4 Ohm at +/-30V, is that possible with a so low voltage?
What is the maximum voltage that can I use safly ,to get more output power
Is this a nice amplifier shematic?
Tanks
Old 16th October 2004, 03:38 PM   #2
jmateus is offline jmateus  United States
jmateus's Avatar
Default 100W car amplifier
O Portimao, Portimao, que saudades....
Lots of current, lots of it....
Check the component parameters and you'll see if it will be
possible to use bigger voltages...
My embrace to Praia da Rocha....
JLH 2005, Cyrus and so on...
Old 17th October 2004, 11:54 AM   #3
djk is offline djk
djk's Avatar
No, of course it can't deliver anywhwere near 100W at 4 ohms. Matter of fact, it will blow up in your face if you try and build it, the bias diodes are all in backwards.
The maximum output swing is very limited by the rail voltage to the IC, then you have to subtract the losses in the output stage.
The NE5532 will only swing a maximum of ±12V when powered off of ±15V, the EF output stage will only get within ±3V of that, so you will only get ±9V output (peak), about 10W at 4 ohms.
Look at an ESP 3A with ±42V, that will do 100W/4R, the transformer would best be a 30-0-30 200VA with a pair of 8,200µF 50V filter caps
http://sound.westhost.com/project3a.htm
New desined 4*100W car amplifier Whortless Car Audio 13 21st July 2011 04:39 AM
search shematic manual akai am 25 amplifier Ground Zero Everything Else 3 24th January 2009 04:55 PM
Good ~100W amplifier percy Solid State 14 10th October 2004 12:31 PM
Kenwood KAC-716 Amplifier shematic viki Car Audio 0 18th September 2004 08:31 PM
AKSA 100W Kitset Amplifier and VAF DC-X's??? sgamma2002 Solid State 2 19th August 2002 08:35 AM
Page generated in 0.07629 seconds (69.85% PHP - 30.15% MySQL) with 10 queries
