Old 15th October 2004, 10:37 PM   #1
still4given's Avatar
Default Extra power transformers
I have two Hafler power trannies that I bought because a tech told me that mine were bad in my two Hafler P230's. It turned out to be the Filter caps instead. So, now I have these two brand new trannies and I'm wondering if they will be of use to me now that I want to learn to build DIY amps. It seems like most of what I read tends to lean more to toroids rather than iron. Is it worth my while to hang onto these?
Thanks Terry
Old 15th October 2004, 10:48 PM   #2
Stocker is offline Stocker  United States
Toroids are in fashion right now, for a few reasons
They will supply the same volts as a big square hunk of iron, wound properly.
If you have a good new transformer that will suit your application with regards to power and output voltages, you either are nuts or have too much money if you want to replace it with a toroid.
Jesus loves you.
Old 15th October 2004, 10:55 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hey Terry,
Keep them for a pair of big power amps that you will build later. I'm very sorry a technician misled you. Another useful thing you can make is a variable (not regulated) DC power supply with bipolar outputs. I use onr for testing and experimenting. Very useful. Put a variac in the primary to adjust the output voltage.
-Chris
Old 15th October 2004, 10:55 PM   #4
Awesome, That's what I was hoping.
Now to find a stellar amp design to build that can take advantage of my trannies.
Blessings, Terry
Old 15th October 2004, 10:57 PM   #5
anatech's Avatar
Hi Terry,
I forgot to mention that the only true reason to use a toroid is to make a case that is not as tall. there is nothing wrong with E-I cores at all.
-Chris
Old 15th October 2004, 10:57 PM   #6
Originally posted by anatech
Hey Terry,
-Chris
Thanks Chris,
That sounds interesting. I'll look into that.
Blessings, Terry
Old 15th October 2004, 10:59 PM   #7
Hi Terry,
-Chris
Great! i hated to think these would go to waste or worse yet I would have to sell them and ship them.
Blessings, Terry
Old 16th October 2004, 12:36 AM   #8
If it helps at all, I have an idea for *my* beast of a transformer:
If you are familiar with the projects from Elliot Sound Products, this will make sense, otherwise I encourage you to do a great deal of research...there are LOTS of good designs floating around here and other websites.
My big idea, if not for a bench power supply, is to make an ESP Project 68 subwoofer amp, high-power version. Combine it with his clipping indicator, and his low frequency equalization circuit for subwoofers in tiny tiny tiny boxes. Combine with a high-power, very high excursion sub and bingo you have a killer home theater/ stereo subwoofer.
My own transformer is oversized even for that application in my opinion, so I am considering also making at least one set of lower power channels for the "highs" and maybe putting the whole shebang in a single box...
oh, to have the time, money and inclination all at the same time...
Jesus loves you.
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Quad II power amps......power output transformers!!! bwes87 Tubes / Valves 3 10th September 2008 02:20 AM
Amp6 -Basic with an extra power cap? mudihan Class D 2 9th October 2006 03:05 PM
FS: power transformers taj Swap Meet 0 1st December 2005 04:31 AM
Page generated in 2.18194 seconds (5.02% PHP - 94.98% MySQL) with 10 queries
