Old 15th October 2004, 09:59 PM   #1
sam9 is offline sam9  United States
sam9's Avatar
Default Bridge Rectifier Question
When selecting a 25A or 35A bridge rectifier there is the option of various Peak Reverse Voltage ratings. Beyond a minimum sufficient rating (400V or 600V), is there any disadvantage other than price for selecting a still higher rating? I.e., if there is no difference in price why not just use the version with a 1000V PRV rating?
Old 15th October 2004, 10:11 PM   #2
Stocker is offline Stocker  United States
The answer IS price, for most commercial kit. If you plan to move 100,000 units, a dollar or three is a big lump of cash.
Jesus loves you.
Old 15th October 2004, 10:57 PM   #3
jneutron's Avatar
Diodes are manufactured in mass quantities. They will be designed to make some ele specs. Speed, leakage, voltage reverse, voltage forward.
Once they are manufactured and passivated, they are tested and sorted by how they perform..in your example, the 1Kv devices may actually have been the same diffusion run as the 200 volters.
Since they can command a premium price for the higher volt devices, they do so..
For the most part, you will find that the higher voltage devices probably have the same forward spec, just higher reverse capability.
Most applications will not suffer as a result of the higher voltage devices, unless the bvr of the diode is used to protect a delicate transistor from reverse transients.
Cheers, John
Old 16th October 2004, 02:03 AM   #4
sam9's Avatar
Confirms what I suspected.
Bridge rectifier voltage question woody Power Supplies 1 1st May 2008 01:47 AM
bridge rectifier question crippledchicken Power Supplies 31 25th April 2008 12:17 PM
Bridge Rectifier question hotscot Power Supplies 14 15th January 2006 05:15 PM
Simple bridge rectifier question. JoeBob Everything Else 51 15th February 2002 08:46 PM
Page generated in 0.06890 seconds (76.79% PHP - 23.21% MySQL) with 10 queries
