I need a cheap/simple amp for biamping purposes. Since I already have two 500VA 2*38V toriod transformers I wan't to use them. But this will create +/-50V a little bit too high voltage for the ESP3A amp, I will use 4 ohm speakers.
So I did some changes to the circuit, but I'm not 100% sure that it will work OK. I know the outputstage could be smaller, but I like when things are a bit oversized. Suggestions?, Comments? /Freddie |
#2 |
Turn up your spice simulator and check the bodeplot for phase margin with ~ 8Ohm||100nF load.
Hopefully your modified amp do not turn more than 160degress. Maybe check the old design too. If they are identical ... Nearly identical i would build Sonny - See Jocko .. i made a post!!! |
| TA-10.1 vs Modified SI | Davet | Class D | 0 | 19th March 2007 07:05 PM |
| IC: Looking to get my T-Amp modified | cmirza | Swap Meet | 0 | 29th May 2006 06:19 AM |
| ME2 modified | MJS | Multi-Way | 7 | 20th October 2005 03:41 PM |
| modified mid-fi? | amo | Multi-Way | 0 | 10th June 2003 01:21 AM |
| Can This Amp Be Modified??????? | OMNIFEX | Solid State | 4 | 11th April 2003 02:37 AM |
