I will appreciate your advise on what are the practical steps to do this task. The amps I use have gains of 63 (The END, LC Audio) and 32 (Thel Accusound). I know what to do in principle but am interested on details, e.g.:
1) what signal I have to use at the input of the active XO (from what source, e.g. test CD, white noise...?) so that the three ways should pass identical levels of output and then I can measure the V at the amp outputs, to be made (the volts) equal for each amp via adjusting the XO output trims. 2) Are there alternatives? (I don't have an osciloscope and hope the adjustment could be done with what I have (multimeter, test CD, ears...) many thanks for your insights! |
#2 |
Did it Himself
Set the XO aside and just feed each input with a 1 kHz sine wave and measure the output voltage with a volt meter. Adjust each amp level control to get the same reading on the meter.
#3 |
Thanks. I was talking about a signal through the XO because my amps do not have volume controls while the XO has trimers at its output. Any idea how to set these trimer pots?
#4 |
Did it Himself
With your ears. It would be pointless setting the voltage at the speaker terminals all the same anyway as the different drivers will have different sensitivities and efficiencies.
#5 |
Is not good to use different amps for active crossover. By my experiences best results are only with the same amps.
#6 |
Upupa, I see your point but disagree. My research has made me believe that you have to combine amps that are particularly good at the respective frequency ranges and this is what I did.
#7 |
I agree, select the amps that best suit the frequency range and accept a bit of resetting to equalise volume due to different gains and sensitivities. In the extreme you might use tubes for the treble, class A solid state for mid & class AB for the bass. Not just differnt makes but a whole different philosophy. The problem might be finding a set of matching (nice sounding) amps to experiment with.
#8 |
I'm standing along by my words
| Different Gains Correction (VAS solution) | Stee | Solid State | 2 | 8th September 2008 02:49 AM |
| Follow up to cap sleeve thread,Wire color makes a diffrence!! | CryingDragon | Parts | 48 | 24th April 2008 02:07 AM |
| Opamps and Gains | mudihan | Digital Source | 14 | 18th July 2006 02:42 PM |
| gains with lm3886 | Doovieman | Chip Amps | 6 | 13th July 2005 05:04 AM |
| Page generated in 0.08223 seconds (76.06% PHP - 23.94% MySQL) with 10 queries |
