Recommendations for Internal Signal Wiring
Old 14th October 2004, 05:34 AM   #11
troystg is offline troystg  United States
troystg's Avatar
Hi mhb-
"Make sure and ground one end of the shield, I won't say which one to avoid wars, just try it both ways and go with what works best."
I totally agree with that statement. I have always perferred one method but everyone has an opinion.
As for unsheilded runs, at a MINIMUM I would twist the hot and common leads..
RF is everywhere and quite pervasive. I screened the pwr leads in my GC. As a result, it is DEAD quiet. ZERO noise even at the speaker.
Good luck,
Troy
Old 14th October 2004, 12:03 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Killjoy99,
Most people here seem to recommending common sense. Use wire designed for whatever task and lay it out carefully. I buy my wire where it's most convenient to get to as I travel a lot.
If you have a wiring fault that will overheat wire, a fuse should have gone or the guage is too small. Exotic wire is not required, but if it makes you feel better ...
-Chris
Old 15th October 2004, 08:15 AM   #13
Upupa Epops is offline Upupa Epops  Czech Republic
To Magura : Are you working in rocket industry ?
Old 15th October 2004, 08:34 AM   #14
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Re: Recommendations for Internal Signal Wiring
Originally posted by Killjoy99
Just looking to get some recommendations on the particular kinds and brands of signal wiring within amplifiers. I'm having a hard time finding adequate signal wire by the foot. Any help would be much appreciated.
Just have a look at this post.
http://www.diyaudio.com/forums/showt...200#post492200
Old 15th October 2004, 08:45 AM   #15
This pure silver you can get only by transmutation, which, as I know, nobady knows ( in industry form ) .
Old 15th October 2004, 08:48 AM   #16
Banned
Lightbulb Pure Silver
For your information: it is done by a process called zone melting just the way pure Silicon is produced for chip wafer manufacturing.
Old 15th October 2004, 08:49 AM   #17
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I use CAT5 wire -- bought from Radio Shack or pulled out of a dumpster --
I also have some teflon insulated wire which I purchased at Electronic Surplus --
for power supplies I use the #12 STRANDED from Home Depot in Red, Black and Green.
btw, Bob Pease pointed this out at National Semi's website -- we all know the standard physics equations for L and di/dt, or C and dv/dt, if you have to measure small voltages note that there can be a dC/dt term if the cables are jiggled in the least!
Old 15th October 2004, 08:57 AM   #18
To Also : Yes, I know zone melting , but how is temperature conductivity of silicon and how is silver one ?
Recommendations for Internal Signal WiringHide this!Advertise here!
Internal Wiring... Tomv Multi-Way 1 23rd November 2007 08:53 AM
dac internal wiring sparkle Digital Source 16 8th May 2005 10:52 AM
Preference in internal wiring P2P and signal Henrik Juhl Chip Amps 5 22nd December 2003 07:20 PM
Internal wiring KenP Solid State 18 6th December 2002 09:59 PM
Internal wiring 2Bak Parts 5 29th July 2002 09:37 PM
