Hi everyone just wandering if anyone has or knows where to get a datasheet for an NJM2068SD, The original part im repalcing is an NJM2068LD made by JRC.I have searched for a few days now and can not seem to find a datasheet. I ordered this part thinking it would be the same but instead of 8 pins its got 9 pins, I was hoping to find the datasheet and see if there is any way i can use this part instead of the original as i cant get hold of them and i need 8.. Please help.
Regards Bowdown |
#2 |
Dear fellow Aussie, how's things out West? You may get some joy at http://www/icxinyi.com/EN/zlsearch.php I just put the part number plus the word data in "google" and got a couple of pages (some of which were in Eng.) This one looked promising but they will want money for the info' I suspect. If you put your original part no. in "Google" it seems to throw up quite a few sites. I think one said it was a dual op amp' is that right? Good luck.
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#3 |
Hi, As far as I can find at NJR: http://www.njr.co.jp/e_frame/ef_00_ske.html
Have a look or ask them more info. Another source: http://www.alldatasheet.co.kr/ http://www.datasheetarchive.com/ Cheers, Tarzan |
#4 |
Pinout for NJM2068SD:
1: V+ 2: A Out 3: A -In 4: A +In 5: V- 6: B +In 7: B -In 8: B Out 9: V- /Hugo |
#5 |
That pin out is not correct.
The power supply pins are wrong, pin 9 is also V+ The 9 pin sips are made so you cannot put them in backwards. |
#6 |
I guess you are correct, djk
Thanks for pointing that out We can blame the Grundig engineers here. Pinout: |
#7 |
Part of schematic:
| help finding best amp and schematics. | dudio_me | Car Audio | 8 | 17th December 2008 07:48 PM |
| help finding sub | chainenoble | Subwoofers | 5 | 10th April 2006 04:25 PM |
| Need some help finding these | homemade | Parts | 4 | 8th October 2005 09:17 PM |
| Help in finding Amp | chopperluf | Car Audio | 0 | 26th August 2004 02:10 PM |
| finding qes and qtc | DREW028 | Multi-Way | 3 | 27th July 2004 11:25 AM |
| Page generated in 0.08786 seconds (76.06% PHP - 23.94% MySQL) with 11 queries |
