Dear all DIY gurus,
I have some questions about the IC modules. These modules are used in my integrated amp and are located near to input RCAs. As shown in the picture, a module says "2058D JRC M1017G". And the other one says "2058D JRC M1021G". Are both of them basically common opamps? Which grade are they? Can I change these modules to better ones? If I can, which models or brands should I consider? Thank you. |
#2 |
Some chip with 4 operational amplifiers inside?.... check the LM324 and see the supply pins, also the input pins...and touch them with small metal to see if sounds!!!
If sounded, we discover some cousin.....yeahhh..... if not....better to cry. because could not see in the internet. Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#4 |
I think that's a JRC quad OP also called NJM2058D. Made also by Harris:
http://www.njr.co.jp/pdf/ae/ae04019.pdf
UrSv Those who say it can't be done should not stop those who are doing it. |
#5 |
The swedish hamburger...hummmm good!
Carlos
#6 |
Thank you so much for every feedback. I have three more questions.
- Now I think it is actually NJM2058D, but what is the difference between M1017G and M1021G? - Which grade are they? Regular? Decent? or Audiopihle? - If they can be upgraded by other equivalent modules, which ones should I try? Thank you |
#7 | |
/U. |
#8 | |
Hi Hjelm
I myself was looking for the ID of an IC of my plate amp. I first thought dat it was JRC 20600 M8009G. It appears to be, after another close look, 2060D. By the link you provided I did a search for NJM2060D and presto, it came up. Now I know it's an op-amp and will be able to repair my plate amp. Thanks man! Cheers Walter |
| Advice For My Tired Bookshelf Speaker -- With Pics | ted777ted | Multi-Way | 9 | 25th August 2005 06:15 PM |
| Replacing IRFZ42 in Alpine 3558 advice needed....(pics) | maxw | Car Audio | 20 | 8th July 2005 07:16 PM |
| Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice | moving_electron | Chip Amps | 0 | 16th February 2005 12:37 AM |
| Pinoy DiY'ers, FT1600 pics..pics | dranreb&* | Full Range | 5 | 3rd November 2004 10:21 PM |
| PICS: GainClone Monoblock pics | Rarkov | Chip Amps | 19 | 17th April 2003 07:37 AM |
| Page generated in 0.10141 seconds (78.96% PHP - 21.04% MySQL) with 11 queries |
