Hello,
I'm looking for a good solution to prevent RF and GSM detection with my amplifier, I now it could be done by filtering the input. The input is a basic differential pair as on the following file : http://www.diyaudio.com/forums/attac...&postid=488146 ps: there is no more DC offset ... Any advice is welcome. David |
#2 |
was it a stupid question ? is case of the amplifier supposed to stop all the RF ?
David |
#3 |
The problem is that RF can get in anywhere - not just on the input. Also the wires to the speaker are excellent antennas for RF. So if you have a problem with RF you can try the old trick, which is to do one winding round a ferrite core ring or using one of these: . . .wel . . . please do a search on Farnell using this search word "535886". Then you will get the picture
Ohterwise you can make an input filter. I recommend using 1 MHz as cutoff, so you will not interfere with the audio signal too much - fase and amplitude wise.
Best regards Bo |
#4 |
Electrons are yellow and more is better!
Good RF immunity comes also with a good pcb with groundplane but as a start and good decoupling and a LP-filter at the input.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
You need to add R2 and C1 to your input stage:
http://users.ece.gatech.edu/~mleach/lowtim/instage.html R2 - 2K C1 - 390 pF mica (Arco DM15-391J or DigiKey 338-1057-ND A ceramic cap may be used if nothing else is available. |
#6 |
thanks, I'll try that, I hope my GSM phone won't "sing" in the loudspeaker anymore.
| differential design, common mode noise rejection | Sebastiaan | Solid State | 0 | 17th April 2006 08:16 PM |
| Ripple rejection caps - multiple? | tonyptony | Parts | 4 | 23rd March 2006 06:58 PM |
| Power Supply Noise Rejection Ratio's (PSRR) | Dr.H | Digital Source | 4 | 23rd July 2005 09:26 PM |
| Will AD1896 improve jitter rejection? | yejun | Digital Source | 4 | 2nd July 2003 09:23 PM |
| Ultimate noise rejection | annex666 | Everything Else | 2 | 29th July 2002 06:57 PM |
| Page generated in 0.09326 seconds (69.82% PHP - 30.18% MySQL) with 10 queries |
