One Channel of JLH 80w Mosfet Louder than other
Old 11th October 2004, 11:51 AM   #1
foxyb is offline foxyb  United Kingdom
Question One Channel of JLH 80w Mosfet Louder than other
I have build that jlh 80W mosfet amplifier, from the ETI articles in the mid 80s, using Hart provided boards, and upgraded components.
I have replaced most of the transistors in the differential input stage, the voltage amp, but NOT the output stage, as they are relatively expensive SJ50, SK135 mosfets.
One of the channels is about 20% louder and may have a higher (correct?) frequency content than the other. The volume difference can nearly be adjusted out with the aid of a 2k2 trimmer pot. It has been like this since I built it, and I have ignored it till now.
To fix this, do I have to have access to a variable frequency voltage source and scope (like I did when I built it), or is there a more basic series of checks I could do?
If it needs specialist AC sources and scopes, then it will have to go to a local hi-fi repairman, whom I will have to show the circuit diagram and hope for the best.
The circuit is a 3 stage ac coupled amp with a differential input with active loads, a voltage amp with active loads, and mosfet emitter follower output stage. It looks like it has 2 stage feedback, a loop from output, and another from the input to the emitter follower.
Any assistance would be much appreciated, as in spite of the volume difference it does sound very nice.
John
Foxyb
Old 11th October 2004, 04:07 PM   #2
Hornlover is offline Hornlover  United States
Maybe this is obvious, but did you check to make sure all resistors are the proper value? Maybe a wrong value slipped in there during assembly.
Old 12th October 2004, 01:14 AM   #3
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Hi John
Inspect the accuracy of the feedback resistors...
Jorge
One Channel of JLH 80w Mosfet Louder than otherHide this!Advertise here!
NAD 7100 / 3100 - one channel louder than the other mashley_nad Solid State 10 7th September 2010 06:05 PM
CFP with N-channel mosfet and PNP? AudioGeek Solid State 2 23rd May 2005 02:44 PM
Low Ron N-channel MOSFET Devil_H@ck Parts 17 24th June 2004 07:31 PM
One channel is louder than the other? ble0t Chip Amps 30 12th June 2004 04:04 AM
One channel louder... Rotel RA-971 rsdent Solid State 3 22nd April 2004 04:09 AM
