three prong receptacle with 50 volts on ground - Page 2 - diyAudio
Old 12th October 2004, 01:15 PM   #11
kilowattski's Avatar
There is no ground wire or metal conduit and therefore no actual grounding.
I ran all new circuits for my amps 2 30 amp grounded circuits and was using this 20 amp circuit for the microelectronics.
I still say that wiring a circuit with no ground is dangerous. I am sorry if I sounded a little harsh. I was not attacking you personally, only trying to impress that no ground is dangerous.
Kilowattski
Old 12th October 2004, 01:31 PM   #12
joensd is offline joensd  Germany
Sounds like a leakage to me as well.
Have the exact same problem right now and just took one fuse after the other out until the problem was gone.
Looked in the house which fuse it was and wasn´t too surprised that it was the old fridge causing this.
BTW: I got slight shocks touching the toaster and the oven because of this so you should solve this asap.
Kids do get harmed more seriously.
jens
3 prong speaker Bob0513 Multi-Way 15 8th March 2008 02:34 AM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 03:52 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 01:10 AM
2 To 3 Prong Conversion amaturetuber Tubes / Valves 3 8th May 2005 11:20 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
Copyright ©1999-2017 diyAudio
