Few years ago I made the amp that can be seen in the attached file. Some visitors who were used to listen to the plastic audio were satisfied with its sound. Any comments, folks?
#2 |
Czech humour?
#3 |
Seems it greatly depends who is a thread starter. Sometimes evaluated as "minimalistic simple ZEN concept", sometimes as a Czech (black) humour. Go on, please
#4 |
This BU208, i remember,.... some hi voltage to TV fly Back transistor, to Black and White old television.... good Pavel.!...i like to put this to work in my club.... same volume with a 400 watts Marantz.....of course Marantz at minimum power.... operating class A because of bias... and sounds good!... sometimes we feel confusion.... not perfect because transformers, not all, normally turns the sound a little worst.
regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#5 |
Hi Carlos - yes, you are absolutely right. The HV TV transistor. Not easy to withstand rectified mains voltage. No power transformer was needed, only one must be a bit careful not to reverse the L and N conductors.
#6 |
Maybe is better use there only one transistor, best will be IRF 730 with splendid high input capacity, which make wonderful satin smooth sound
#7 | |
#8 | |
PMA wrote:
M |
| Specific transformer based I/V | matejS | Digital Source | 1 | 8th October 2007 05:50 AM |
| Transformer based feedback? | bigwill | Solid State | 25 | 6th January 2006 08:02 AM |
| Transformer based phono stage | biovizier | Solid State | 7 | 31st October 2005 09:12 PM |
| Transformer based audio isolators | fuzzboy | Instruments and Amps | 7 | 27th March 2005 02:11 PM |
| Transformer Based Passive Preamp | wytco0 | Solid State | 5 | 6th September 2004 06:58 PM |
| Page generated in 0.09910 seconds (74.95% PHP - 25.05% MySQL) with 11 queries |
