#971 |
Banned
Yep Sheldon,
Seems like these devices tick all the boxes for a nice simple circuit in a simple & unique circuit - wonder if Susan is listeneing in? Interesting to hear how it will sound - reports seem exemplary John |
#972 |
The only problem with the Lovotech devices is their low breakdown voltage. This will limit the output power available unless the parts are operated as the lower half of a cascode.
#973 |
Banned
Wrenchone,
When operating them from 12V SLA this should be OK I think? John |
#974 |
Just barely...
#975 | |
Sheldon |
#976 |
Banned
Oops might need to order more than 2 matched pairs then - will probably regulate voltage anyway and while I'm at it keep it down to 10V to be a bit safer - is there any other way of using these devices in this amp config which will result in safer operating area?
John |
#977 | |
expert in tautology
Until you get them very too hot, then they give up the neg tempco idea and run away... In fact it is difficult to bias up Mosfets past a certain standing current unless you can keep them very very cool, they try to track back to where they want to sit... _-_-bear :Pawprint
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#978 | ||
Hi All,
I trust everyone is keeping well. I have been busy with work stuff so not so much time for audio these last few months. Quote:
However I have used Supertex DN2535s for a Zeus PP line-driver http://www.supertex.com/pdf/datasheets/DN2540.pdf see some preliminary testing at: http://www.audiophonics.com/audiopho...vmos-pp-1.html They give good results. Note however that the termination of X1's secondary has to be matched to the driving source impedance otherwise there can be significant HF peaking before rolloff. This circuit always operates in Class A, so the auto bias method is okay. Voltage rating is 350 or 400 volts, so no problems here with a 24 volt supply. The DN2535 has a max current of 500mA and 15W so would need to be paralleled up for an output stage driver. And I would not auto bias (unless always in Class A with a big step down ratio) so having to do a separate negative bias plus multiple devices somewhat increases the complexity and makes for a potential failure mode if the bias doesn't come up properly. Using standard MOSFETS removal of the positive bias voltage effectively puts the amp into standby, which is a useful feature for energy savings when the amp is not in use. Best wishes, Susan. |
#979 | ||
Nice to see you here. I did try one channel with the regular Mosfets, the 801 driver, and an autoformer for the input. Got tunes out and sounded fine on a small speaker. I've got an RIAA project to finish first, but then I'll play some more with this one.
Sheldon |
#980 | |||
Note from my VMOS schematic that the gate zeners are reversed in polarity. And here should probably be reduced to 9 volts. Also don't forget the current capability of the transformer windings, as with these high biases there will be some heating. One of the problems seems to me to be the package as it isn't overly big for the types of currents and wattages proposed. I know that it is theoretically capable of 65 watts but once one has derated at higher temperatures e.g 80 degrees C it is only about 30 watts and the package has a thermal resistance junction to case of 1.8 degrees/watt - compared to 0.69 for TO247 But high bias with low voltage is certainly one way to go. Per STW34NB20 I use 750mA at 34 volts supply in my standard power stage. Will be interested to hear how this version fairs. Best wishes, Susan. |
