#61 |
Dear Susan, Dear John,
thanks a lot for your responeses about the RF amp. It's just a quick idea the same as using a lot of OPs and parallel them. I know the RF design is completely different from power amp design. But 40MHz and about 2MHz what I got with the fastest designs developed for audio seems not so far away. On topic - Susan you really ashamed me. When I started 25 years ago building amps first I learned is to use feedback. Well that had some tradeoffs I build more oscillators than amps. Another 10 years later - my amps are more stable that time - I read, that a lot feedback will cause some audible problems. So I removed feedback with the effect of more complex circuits. I also build some tube amps, no power but headphone and preamp. Yes they are looking very nice, that glowing is really impressive. And that gave me the inspiration to make semiconductor amps better. Well, some power regulation / stabilisation here some CCS over there, I think my latest designs are not much more simple than that commercial stuff (I repaired a lot of them in the past years!) And now you came with a two transistor design, added two transformer in the in- and output. Just like that golden time where transistors cost more than transformers. And you tell me it sounds good. Shall I really believe this? As well as tube amps they are all from an ancient time. Cum on we're living in a time of highly integrated semiconductor chips, computers, where billions of transistors are in and connected in a very complex manner, this cannot be true. Why we need then the use of the other billion transistors? They cannot be out of job! Using some high quality parts, the less as possible in the signal path and made it in the RIGHT other way round. Susan - your design is really cool. |
#62 |
Susan,
On the other hand, while I am sitting here listening to Norah Jones through my Nemisis monoblocks, I wonder why one would need per channel no less than 2 transformers and two transistors, when half of that would be perfectly adequate... But, Susan, seriously, are you familiar with the Nemesis? Do you hasve an opinion on how your amp would compare to that, soundwise? Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#63 |
Jan, one is too much - maybe best result give you horn and shelack with 78 rpm
#64 |
Hmmm... I wonder if this amplifier was originally made with P-channel fets but later got changed to an N-channel cct so that's what it is now?
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#65 |
Wahey! Only just read this thread. I love that topology Susan! My present single-ended amp is in the same spirit but uses a single 801A valve in each channel with a Lundahl amorphous core stepup on the input as driver. Works a treat and everybody who hears it wants me to build them one. Need sensitive speaks though
![]() Semper Musica! Semper Simplistica! Brian. |
#66 |
Hi everyone,
Many thanks for your continued interest. I have reasembled my test setup to be able to make some of the measurments requested and incorporated this in updates to my amplifier web page: http://www.susan-parker.co.uk/zeus.htm which now have links to two transformer spec pages. Some highlights... Input impedance = nominal 150 ohms parallel and 600 ohms series wiring of primarys. Termination resistance is 120 k ohm. Output impedance is 2.78 ohms at 1 kHz. Laminations are 0.35 mm thick. There is also inductance etc. for those happy bunnies who can make working Spice transformer models. Of course one also needs working mosfet models, but that is another thread. Best wishes, Susan. |
#67 | |||||||||
Hi Graham.
Parallel = 165 Ω. Series = 667 Ω. I normally use parallel mode whcih gives me a 1:10. Series is 1:5. As you have probably noticed my amplifer is a power stage, and does require a seperate driver after the attenuator section. This is a different split from normal but based on technical reason not some glitzy marketing speil. Quote:
I also want to try using some mu-metal interleaving. Quote:
I set for reasonable disapation. There is some change as the bias kicks in. I have some test gear (including an HP Audio Analyser) but need to sort out and match some power devices - plus the time to do this as I have some short term work pressures. Quote:
I understand the 100 W - 8 ohms but in my experience I rarely use more than 5 W or so except for daytime classical listening (the loud bits). A lot depends on the speaker sensitivity. I don't beleive that it is possible to completly remove the loudspeaker's reactive and frequency effects on the feedback network of the amplifier. It can be minimised for a certain range of conditions and tuned to a preference, but it will always be there. The only wayI see to make a feedback amplifer work without artifact is to have two output stages, one with a non inductive load of say 12 ohms (or whatever would be a good overall match to the nominal loudspeaker impedance) and used for the amplifier feedback, and the second slaved but WITHOUT any feedback connection which is used to drive the loudspeaker. Obvioulsy the output devices have to be matched and closely mounted on a "nice big heatsink". As to my transformer design - it's a third type, neither valve or solid state, and doesn't to my ear have the same sound as either. Personally what I hear most is the quality of the source material rather than a "valve" or "solid state" sound. But one becomes used to what one listens to, which I would agree doesn't mean the same as better (or worse for that matter). Quote:
I am thinking about other drivers - more conventional but less expensive. Many thanks for your time and interest. Best wishes, Susan. P.S. Sorry it's late now, I will have to reply to other posts tomorrow. |
#68 |
http://www.stereophile.com/amplifica...40/index6.html
Speaking of single-ended amplifiers, it's worth noting the work of Paris-based Jean Hiraga at L'Audiophile over 10 years ago. He developed a single-ended, transformer-coupled transistor power amplifier called Nemesis, with no other active devices whatsoever other than a single power device (namely a 25SK 135 power FET). The Nemesis's utter simplicity helped it achieve a sound that closely approached that of a classic WE 300B single-ended triode amplifier.—Martin Colloms Audiophile n°34, janvier 1985 Audiophile n°35, printemps 1985 |
#69 | |
Hi Dimitri,
Thank you for the reference... Quote:
However the Nemesis is a valve design with the power fet instead of a tube, and the gain stage is the FET transfer characteristics, which as Eva has pointed out are a bit shakey. These single ended designs by their nature have an ASYMETRIC output impedance, which will affect the reproduced sound quality. They can only drive in one direction, the other direction is dictated by the back EMF of the transformer or by the current sink. Again this is not necessarily good or bad, it's just how it is. My amplifier uses an impedance gain stage, which does not add any noise. It is literally "wire with gain". To do this voltage amplification I trade off a low impedance input for a high impedance output. Of course, as has been pointed out by several people, transformers are not linear in the same way as a feedback loop amplifier. But then I am not aiming for 0.0001% THD into a non-inductive 8 ohm resistor - because listening to a resistor is very boring! My amplifier is push-pull off a single supply rail which gives a number of advantages. 1. Very high supply ripple rejection - small (i.e. cheep) smoothing cap. 2. Active drive in both directions at all times - constant impedance. 3. Low quiescent bias - circa 500 to 600 mA - less heat. ... but I am beginning to repeat myself, which is also boring. Sufficient to say I am not trying to reproduce a Triode sound (nor a solid state sound for that matter). I am trying to reproduce the sound encoded in the original recording - no more, no less. It should be remembered that the average signal for a classical CD with large peaks is only around 12 bits resolution, i.e. 1 in 4096, which is 0.025% distorsion before one even starts with anything else like the woefully inadequate sampling rate of 44 kHz. I know this because I built my own CD player using a CD-ROM drive and striped out the digital audio data from the signal processing chip to feed into my own Burr Brown DACs to then drive my amps directly. All this oversamplig filter stuff is a fudge, and introduces it's own signature to the sound. It can be a very good fudge, and be more pleasant to listen to, but that doesn't negate the fact that it is modifying the original sound. Any item that can be interchanged with another of similar function and that results in a different sound will be doing this, with the one exception of the single item in the group that isn't modifying the sound. But that one probably won't be recognised as such, given that each will be subtly (or not so subtly) different anyway. So at the end of the day it comes down to personal choise and preferance (and spelling) and what works best for one person isn't necessarily going to be good for another. Best wishes, Susan. |
#70 |
Whatabout damping factor, Susan ? Do you think, that several ohms is good ? By this value is bass like snowball throwed on tent
| Page generated in 0.09074 seconds (80.97% PHP - 19.03% MySQL) with 11 queries |
