#541 | |
On the other hand, I agree that THD and IMD as a simple number does not say much, that's why I am speaking about the necessity of spectral analysis. |
#542 |
Hi Everyone,
This weekend has been busy for me so only just back at my computer. Will reply to questions asap. I have set up and measured the noise figures for the amplifier with the STW34NB20 PowerMESH mosfets. Measured across the 8 ohm load. Test setup on bench. No special grounding or other tweeks so some of the noise may still be pickup in the leads etc. as it is very difficult to measure down at these levels. Measurment bandwidth is 10 Hz to 100 kHz. Full power is 20 Volts ac RMS - 50 watts - just into clipping. Noise is 13 uV (micro-volts). Best wishes, Susan. P.S. Have to make supper now. |
#543 | |
Hi hostmaster ,
http://www.susan-parker.co.uk/zeus-toroid-amp-1.htm Input Transformer - 15VA Bandwidth: 10Hz to 25.5 kHz (-3 dB), 31.5 kHz (-6dB) With modern winding and construction techniques I am hazarding that the transformers will be similar enough to give those sort of figures. At the end of the day one has to try one out. These are made for 50/60 Hz mains and the wideband performance is much better that I would have thought. At least the cost is small relative to custom transformers. Best wishes, Susan. |
#544 | |||
Hi extremy,
If you are making a full transformer rather than a center tapped inductor then the best way is to wind all the wires together. With 1.0 mm wire you could just use three windings although four would be preferable. If you can wind all the turns in one go then that is best. Separating the windings into layers - whilst functional - decreases the coupling and reduces the bandwidth. However this may still be more than adequate. I haven't tried winding one (yet) so I can't judge the performance. Quote:
Have to use the decoded outputs as Dolby won't license their decoder unless one has a big factory churning out boom boxes. Quote:
#545 |
Dear All,
Just checked the output impedance of the amplifier with the STW34NB20 PowerMESH mosfets and the 75 watt transformer. It's 0.9 ohms That's configured 2:1 with two paralleled 1.0 mm output windings. Best wishes, Susan. |
#546 |
Dear All,
Some "real" test results now at: http://www.susan-parker.co.uk/zeus-t...9-fft-1khz.htm Best wishes, Susan. |
#547 |
Dear All,
From Sowter: ============= The price for the would bobbin only is UKP 72.25 each. Complete transformer is UKP 128.95 each. We will assign the type number 9840. Anyone can use this to order. S/T/O suffixes as normal for the Fully Shrouded / Drop Through / Open Frame options with dimensions and weights for the N type. SOWTER AUDIO TRANSFORMERS (E A Sowter Ltd) Web site: http://www.sowter.co.uk SALES: sales@sowter.co.uk SUPPORT: support@sowter.co.uk ============= Best wishes, Susan. |
#548 | |
Is there a big noticable difference compared to the IRFP's? (given that there's no chance for A/B testing) |
#549 | |
Hi Darkmoebius,
The bass seems tighter with the bigger transformer and lower output impedance, but that could also be due in part to the TI headphone amp drive to the input transformer. I need to make up a pair of amps that I can A/B test against my original monoblocks. BTW there are now FFT tests on my original amp at: http://www.susan-parker.co.uk/zeus-o...s-fft-1khz.htm Which has pics of how it is built, plus a HP 8903B distortion v power level for both 2:1 and 4:1 output transformer configurations, plus 1 watt and 2 watt FFTs. ![]() I have used the HP generator as I have to be very careful about not blowing up the soundcard input and I am still sorting out my methodologies to ensure that I don't. I am confident that the results will improve with the FFT software's internal generator (the stuff above 8 khz in particular). Best wishes, Susan. |
#550 |
Dear All,
Added Sowter information to this page. http://www.susan-parker.co.uk/zeus-out-tx-75w.htm And started on a page for construction information, notes and hints at: http://www.susan-parker.co.uk/zeus-construction.htm Best wishes, Susan. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| True Sound |
| Page generated in 0.10371 seconds (69.64% PHP - 30.36% MySQL) with 11 queries |
