#161 | |
Account Disabled
Assuming of course, that there are no nasty surprises at HF with non-standard loads.... |
#162 |
Hi Susan,
The mid range distortion figures show that the amplifier is 'characterising' the sound. This is where fundamental nulling will reveal what the amplifier is adding. Cheers ........... Graham. |
#163 |
MOSFETs IRFP150
Supply 34.00 Vbias 3.88 Q1 bias 0.217 Q2 bias 0.233 Load 8.02 Frequency 1.00 kHz Watts AC-RMS DIST% 40.4 18.00 0.340 36.1 17.03 0.268 32.3 16.11 0.250 28.5 15.11 0.305 24.6 14.06 0.374 21.2 13.04 0.411 18.0 12.01 0.449 15.4 11.13 0.485 12.5 10.00 0.526 10.1 9.00 0.570 7.98 8.00 0.616 6.18 7.04 0.654 4.56 6.05 0.679 3.20 5.07 0.684 2.00 4.01 0.612 1.18 3.08 0.437 0.78 2.50 0.275 0.50 2.00 0.156 0.38 1.75 0.115 0.28 1.50 0.076 0.19 1.25 0.048 0.12 1.00 0.034 0.10 0.90 0.030 0.080 0.80 0.026 0.061 0.70 0.027 0.045 0.60 0.016 0.031 0.50 0.028 0.020 0.40 0.041 0.011 0.30 0.028 0.008 0.25 0.030 0.005 0.20 0.030 0.003 0.15 0.055 0.001 0.10 0.115 Notes: This test uses the original ST brand IRFP150 mosfets as fitted to the amp in the picture. The mid power bump is at a little higher power than that with the IR IRFP140, but slightly lower in distortion. The amplifier starts becoming power supply limited at 17 volts RMS. 100 Hz distortion figures are similar or slightly lower. Tested with 500 kHz measurment bandwidth. ======== Low frequency power curve - Hz versum maximum AC-RMS at that frequency. Load 8.02 Hz AC-RMS Watts 10.0 8.03 8.036 11.0 8.69 9.411 12.0 9.20 10.548 13.0 9.90 12.215 14.0 10.51 13.766 15.0 11.03 15.162 16.0 11.76 17.235 17.0 12.29 18.824 18.0 13.10 21.387 19.0 13.60 23.051 20.0 14.10 24.777 21.0 14.64 26.711 22.0 14.93 27.780 23.0 15.40 29.556 24.0 16.14 32.465 25.0 16.39 33.479 26.0 17.05 36.229 27.0 17.55 38.385 The above is limited by the line driver's ability to drive the input transformer. ===== 4 ohm load distortion figures are higher (this transformer does not have split secondaries - so it is not properly matched to this lower impedance). Load 4.00 Frequency 1.00 kHz Watt AC-RMS DIST% 25.0 10.00 1.853 20.3 9.00 1.302 16.0 8.00 0.768 12.3 7.00 0.846 9.0 6.00 0.933 6.3 5.00 1.031 4.0 4.00 1.135 2.3 3.00 1.232 1.6 2.50 1.230 1.0 2.00 1.094 0.77 1.75 0.942 0.56 1.50 0.727 0.39 1.25 0.408 0.25 1.00 0.282 0.20 0.90 0.194 0.16 0.80 0.152 0.12 0.70 0.122 0.09 0.60 0.089 0.06 0.50 0.072 0.040 0.40 0.060 0.023 0.30 0.044 0.016 0.25 0.027 0.010 0.20 0.011 0.006 0.15 0.010 0.003 0.10 0.058 ===== Best wishes, Susan. |
#164 | |
The figures do not change when I use the 80 kHz or 30 kHz low pass filters. Once one has the input transformer any HF is filtered out. ... but it is important to know how the circuit sections behave. I was involved in EMC/RFI conducted and radiated emissions testing of a battery/mains powered smoke alarm recently. All very low power stuff and a low few hundred hertz tick for its internal function. Perfectly safe one would assume, and no emissions to worry about. However it nearly failed the radiated emissions tests. Whilst in quiescent mode there wasn't a problem, but when the smoke unit was alarmed i.e. sounding it's pizzo horn, it was radiating up into several megahertz at a figure than was 80% of the test level failure point! So much for low power and innocuous! Best wishes, Susan. |
#165 |
Susan,
I've followed this thread with some interest... Of course, you've fed bits and pieces out to the hungry little birdies! It would be nice if ur webpages had an index so that someone could look at the parts of the design? If there is one, I don't know where to find it... certainly not from your home page? With regard to the transformer specs, imho it's a bit like cheating to lightly load the transformer and test it. There's a certain "toroidal" output transformer company that shows rather remarkably good specs, but if you read the fine print they're testing it at a fraction of the practical operational levels for core saturation. In general, for everyone else reading along, the multi-filar wound output transformer in the *low impedance* & *low turns ratio* variety tend to have substantially better resulting specs than do the usual output transformers. Typically bandwidths out to 250kHz. are possible whereas doing the same thing with even relatively low plate Z output transformers (like for a 300B) is not quite so easy, if acheivable at all. No doubt this design has all the hallmarks of the most popular "DIY" style amps - like the original ZEN. What are those? Almost no parts, nothing to align or test, and ultimate simplicity. Hey, that's good! The rub comes in the details - while almost anyone can build such amps, and they do make sound (sometimes good sound), there are usually several points of detail that do require some careful control and measurement to make the final practical project operate as well as the expectation of the "test bench" results indicate. This one is no different in that regard. Among the points that need to be addressed still are: - the effect of DC offset (device to device) - the effect of bias offset to correct the DC offset wrt linearity - what the optimal bias point is on the curve - effect on power and frequency response of non-flat impedance loads - and some other stuff that escapes me at the moment Wrt the square wave response - I would not be satisfied with that result in any amp that came across my bench. It holds potential, but that ringing (imho) is a defict that is audible. Damping it might screw the overall response, or it might not depending on how or what the cause is/was... is it inherent to the output xfmr or? Important detail. The use of unity coupled output transformers is nothing new, in case anyone thinks otherwise. What's still not clear to me from a casual following of the thread is the design bias points, and how this design's power output varies with load (with and without the restrapped secondary) - or is it truly a "current amplifier" at all? But there is food for thought here... Put up an index page, please? Regards, _-_-bear http://www.bearlabs.com PS. I have a precision coil winding machine here (USA)
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#166 | |
From valve triode data I would expect it to just keep on rising - so I guess there are two data sheet graphs interacting here. There is a small but noticeable difference between the IRFP140 and IRFP150 device characteristics. This indicates that it should be possible to optimize device type, load and power to maximize the performance of the amplifier to a given speaker. Perhaps not so practical in a commercial product but less of a problem if one is building for oneself. Thanks. Best wishes, Susan. P.S. I would note that the IRFP150s are less well matched than the IRFP140s. |
#167 | |||||||||||
Hi Bear,
I too have sought "clarity". I would mention that I have not been deliberatly feeding out bits n' peices. I worked on the audio bits up to a decade ago and whilst many people have good memory for things I don't. I have also moved several times, ditiching at least 90% of my reference material, and it is a wonder to me that I have anything at all remaining from that time. People have asked questions and I have been going away and actually doing measuments, to the best of my ability and with what I have to hand, in order to give an answer. I have added the other pages to give background and scope to why I got started on my amplifier design in the first place. Quote:
I haven't linked this stuff from my homepage as the amplifier discussion was in this forum, and I have been creating the additional web pages on the fly during the course of this last week. Now that I have done this, when I have time, I may well put up a past projects page along with some other things I have done. Quote:
It may be less relevant to audio but it is relevant to compliance testing where one has to demonstrate from 100kHz (or lower) to 2 GHz (or higher) the conducted and radiated conditions for the amplifier. In Europe there are stringent rules for the assembly and use of electronics commercially and although most people are building for personal hobby use it is prudent to make sure that one isn't transmitting somewhere in the VHF or UHF bands where speaker cables and the like are more than adequate as antenna. Quote:
My test bench results are vanilla and anyone building my design with the components and levels described should get equal or better results. My line driver to the input transformer is now obviously the limiting factor, and this needs to be addressed. However the amplifier works quite happily from the headphone output of a CD player or walkman/iPod. So it is easy to get a basic rig running and then be able to spend time working on the preamp side of things in the knowledge that the overall system will be working at the end of the day. Whilst on paper the quite high distortion levels might seem off-putting they need to be equated with tride valve amplifiers, not semiconductor ones. Quote:
But to give you some answers: 1. One needs to match the device as well as one can. I would suggest to aim for better than 10 mV matching at a bias of 225 mV at each primary of the transformer with respect to ground. 2. See 1 above. Seperating out the bias levels and adjusting them seperatly doesn't seem to make improvments. 3. Optimum bias point depends on a number of things including the device type - the bais levels I am using are at anywhere from 3.5 to 5.1 volts depending on the mosfet. Higher levels van be used with bigger heatsinks, a matter of experimantation. Big heatsinks are very expensive to buy, so a lower bias and therefor lower heat disapation is an advantage. 4. Non flat impedance loads will have effects on any amplifier. Some speakers will work better than others, just the same as with any system. I would look at types favioured by the low power single ended triode brigade as a starting point. BTW The amplifier is designed for normal listning in personal environments, not for Carnige Hall, so I am not trying to address higher power levels. Quote:
I don't have the equipment to do the proper measurments to be able to answer the power output bit. It may not be a "current amplifier" but this is how I understand transformers to operate. Maybe I am wrong in this detail, but it is better than describing the amplifier as a "flux convertor". I come from a digital and instrumentation/control electronics background - so my understanding of these definitions may be different. Quote:
As a matter of curiosity what are the performance figures for your single ended mosfet amp? Many thanks. Best wishes, Susan. |
#168 |
Damn!
I wrote a long reply and the forum software dumped it!! Grrrrrrrrr..... GRRR GRRR GRRRR _-_-bear
#169 | |
Hi Bear.
Perhaps a synopsis of your comments? Best wishes, Susan. |
#170 |
I've lost posts due to software too.
I now write the entire message in MS wordpad, then copy/paste, and I do not delete my copy until I have seen the entry at diyAudio. Cheers ............. Graham. |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.20416 seconds (86.30% PHP - 13.70% MySQL) with 11 queries |
