#1061 |
Hi Susan,
used a signal generator and scope to check the phase of all the windings. Have now got a working Zeus. Thanks very much for your help. I'm just starting to do a few measurements. With 32V rails, a 50ohm source, 32 ohm load what voltage gain would you expect the Zeus75 to have? I've wired the input transformer in series and the output has the 4:1 configuration, i.e. four output windings in parallel. Thanks, James |
#1062 |
It looks like the low temp. solder will work just fine for bonding these little packages to a more substantial heat sink. I used Tix solder (an indium alloy) and Tix flux. It's sold here by jewelery making supply houses, gunsmith supplies, and some other hobby suppliers.
I cut some squares of sheet copper about 3mm thick to the dimensions of a T0-247 package. I brushed a bit of flux in the center of the piece and clamped across the piece in a vice. The surface was facing up at this point. I put a small u-shaped piece of the Tix, a little less than 1cm total on the copper. I carefully tinned the back of the JFET with the Tix. I only had to touch the iron to the piece, as the solder melts at about 135 degrees C. I set the FET on top of the solder U, and applied a pencil torch to the back of the copper. As soon as the FET started to move, I pushed it down on the copper and removed the torch. It hardened before my finger got too hot - within seconds. The bond looks good and tight. Sheldon |
#1063 |
Banned
Hi Sheldon,
See your making progress with the Lovoltech fets - how will you fix the jfet with copper pad attached to a heatsink - using bolts ? - is there enough room for bolt holes in the copper? No deformation of copper took place in the heating - jfet is flat to copper surface? I assume you tested fets after & they are ok. I am waiting for my fets & will be keeping an eye on your progress - please post here your steps so we can all benefit from your experiences. Regards John |
#1064 | |
Sheldon |
#1065 |
Hi Susan, thanks a lot for sharing your excellent and easy-to-build design! One question, if I were to build an amplifier system including the PP line drive and the power stage, fed by a CD player, where is the best place to put in a volume pot in your design? Your opinion?
Best Regards Mark |
#1066 | |
Hi
Best regards, Alfonso |
#1067 | |
Hi James,
HP8903B at 1KHz 50 ohm source impedance Input transformer 1+1:10+10 Sowter Output Transformer 2:1 and 4:1 configurations Load 8 ohms. Set level of HP = 1.00 Vac Across input transformer primaries - series = 0.955 Vac Across input transformer secondaries = 9.47 Vac Output transformer 2:1 = 4.21 Vac Output transformer 4:1 = 2.29 Vac Notes: ====== 50 ohm output impedance results in small signal drop, however this source impedance is necessary to match the Rterm value used across the input transformer's secondaries. Mismatch here results in either restricted bandwidth or peaking just before rolloff. Input transformer gain is 10x across both secondaries. Using headphone type driver with primaries in parallel the gain here is doubled (Rterm may need to be changed). Output transformer "gain" is 2:1 or 4:1 but actual output is reduced somewhat by the load and the follower "less than unity" (which is one of the key stabilization mechanisms of the amplifier when driving the reactive speaker load). I use an 8 ohm load, for 32 ohms the reduction will be less. Hope this helps. Best wishes, Susan. |
#1068 | |
Hi Mark,
For the PP line driver are you are thinking of using the Sowter 9063, or some other transformer? The Sowters are expensive but they are a huge improvement over the previous transformers which in themselves were good. The VMOS PP was envisioned for people who already have a favored preamp, probably tube, perhaps an Aikido or some such. If the CD player has 24 bit DACs can you use digital attenuation (not recommended for lower resolution parts)? Otherwise in the PP circuit one can use a balanced attenuator per channel (switched resistors to maintain the accuracy of the two phases). Something like the DACT switches (which they refer to as balanced stereo)... http://www.dact.com/html/attenuators.html ... probably the 500K version to give a 60K input impedance. Not sure how the matching or the high impedance is going to affect the performance as I have not tried this particular configuration. One could try with a conventional ganged pot to check on the basic operation and ensure bandwidth is not affected (I only have 20K volume pots to hand but can try some fixed resistor divider combinations). Putting a pot in series with the input would also work as a volume control, but the rising impedance will affect the bandwidth (however this may still be enough particularly as you are using CD as the source). Other option is SE and switched attenuator, I hope to have a chance to try out the VMOS parts in this configuration next weekend. Best wishes, Susan. |
#1069 | |
Hi Alfonso,
For the Sowter 1+1:10+10 transformers most standard op-amps don't have the drive capability even though they might nominally be shown driving 600 ohm circuits in their app notes. I use OP275s which work although the bass is a bit light (which wasn't a problem as I was driving the low bass separately). But the OPA552 has high drive capability so should work okay. From the TI/BB datasheet I note that the OPA552 is designed for use in configurations with gains of 5 or greater - from which I assume they are a little "twitchy". I have just got my hands on some of Nat Semi's super dupa new LM4562NA opamps which I will try out this weekend. Otherwise the TI headphone driver works well particularly if using toroid transformers for experimenting. I must admit to still be a little uncertain as to your exact implementation, is it possible for you to show us a schematic? Thanks. Best wishes, Susan. P.S. I have ordered a pair of AD815s to try out. |
#1070 | ||
Hi Susan,
thanks again for your help Quote:
I would appreciate if you can correct me with this approach. Best regards, Alfonso |
| Page generated in 0.10113 seconds (65.67% PHP - 34.33% MySQL) with 11 queries |
