#1021 | |
Sheldon |
#1022 |
Yeah, sorry.
I've occasionally been (rightly) accused of having a tendency to go overboard on a few things, cooling and other details of mechanical construction being a good example. I agree that the key point of the JFET version is the simplicity, derived from autobias and a more robust device. Though these suggestions do not impact the electrical complexity, they do raise the bar with regards to actually building one. I'm requesting a quote for a low-voltage EI power trafo and step-up toroid from a local company now, so with some luck, I'll be able to play with it myself. I'd also like to try it with some 9Ah 1.2V rechargeables, mostly just for fun. I recently measured the RMS voltage over my speaker terminals at normal listening volume, and found the peaks to be less than 2Vrms.
-- "Do not attempt to stop this cicular saw with your hands or genitalia." - Warning Label |
#1023 |
Banned
I'm about to start gathering parts for this - any advice on output transformer for use with nominal 16ohm 82dB effecient Rogers LS3/5A?
Thanks John |
#1024 | |
Sheldon |
#1025 |
Banned
Thanks Sheldon,
Yea I know they are innefficient but funnily enough the SI t-amp gives enough power to listen comfortably in a largish room without the volume being all the way up - about half way - go figure? John |
#1026 |
Hello everyone,
I found this transformer as output for Zeus. Can you please comment before I buy it (AU$100)? http://www.altronics.com.au/index.as...=item&id=M1124 (picture and diagram) High power toroidal transformer for audio use. Input and output windings can be reversed or be configured differently i.e. Input windings series connected for 100V and output windings paralleled for 4 Ohm. Primaries: For 100V line use, connect in series, ie. join blue & yellow. Use grey & brown. Connections: Connected In Series: Input 100V Output 8 Ohm Connected In Parallel: Input 50V Output 2 Ohm Secondaries: For 8 Ohm use, connect in series, ie. join black & white. Use red & orange. For 2 Ohm use, connect in parallel, ie. join orange & black and use white & red. Specifications: Max power: 150 Watt Frequency response: 20Hz - 20kHz ±3dB Dimensions: 110mm Ø x 50mm Weight: 2.1kg Fly lead length: 200mm Thank you Alfonso |
#1027 |
What is the turns ratio?
Sheldon |
#1028 |
Hi Suzan;
you've made a nice implemtation of 100% negative feedback by voltage using symmetrical source follower. Now you may take complementary pair of FETs and remove transformers with distortions they add.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#1029 | |
Sheldon |
#1030 | |
| Page generated in 0.10091 seconds (67.53% PHP - 32.47% MySQL) with 11 queries |
