Old 10th October 2004, 04:43 PM   #11
MikeB is offline MikeB  Germany
MikeB's Avatar
Yes, i'm familiar with currentsources to diffamps, but this way q17
simply passes the current from the 12k to the diffamp, at least tries
to. So without q17 the same current is fed into the diffamp.
For feeding a diffamp a simple resistor is not too bad, but introduces
ripple from psu. The impedance compared to a ccs is no big problem
here, as the voltage across the 12k does not vary much.
The AKSA for example uses a simple resistor, but has a "stabilized"
voltagesupply to the frontend.
Mike
Old 10th October 2004, 05:33 PM   #12
bocka is offline bocka  Germany
Hi djdamix,
change the 12k resistor nearby Q17 to 270 ohm. Add 2 diodes 1N4148 in series from base of Q17 to the negative side of the power supply and change R36 from 1k to 12k. This will fix your problem
Old 12th October 2004, 07:47 AM   #13
djdamix is offline djdamix  France
I'have fixed the problem, The 100u capacitor was bad ... I've changed it and the offset disappear, as on my first amp about (30mV) ... strange ... Anyway as most of you say I'll change the current source (Q17) to something better.
Thanks for all your advices.
David
Old 26th October 2004, 08:38 AM   #14
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Definitely Bocka's idea is what I'd do.
With the base of Q17 going to 0V through a resistor and the collector loaded by the differential amp, the CB junction is nearly forward-biased as mentioned before.
Certainly changing in a 270ohm emitter resistor and adding the diodes forward-biased to V- and a 12k resistor will make a proper current source.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
DC Offset JannaCassandra Chip Amps 3 26th July 2008 03:20 PM
What is DC offset? spooney Car Audio 13 2nd March 2008 10:35 PM
Help With DC Offset Sybex23 Chip Amps 8 15th November 2004 07:11 PM
GC offset janneman Chip Amps 4 3rd July 2004 08:10 AM
GC very low DC offset matjans Chip Amps 7 22nd September 2003 10:24 PM
Page generated in 0.07656 seconds (68.48% PHP - 31.52% MySQL) with 11 queries
