Mosfet oscillation or not - Page 2 - diyAudio
Old 9th October 2004, 08:22 PM   #11
Thanks all for taking the time to read my long message.
Problem solved with just 220r gate resistors. Simple!!
I'm learning that mosfets will even oscillate in a DC system.
Disappointed to discover my heatsinks will only take 120 w for a 50 degree rise. but now I can rewind my toroids to give 40vDC and the Class A amp Iq=3a is my target.
Thanks again
Andrew T.
Old 9th October 2004, 09:45 PM   #12
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
A little OT here, but you can put PC case fans on the heatsink (12V) fed with 5V (quiet!) to get a nice temp drop. I'd use two per HS to make sure nothing bad happens if one dies.
We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines. Measurements can provide a measure of insight, but are no substitute for human judgment. Nelson Pass
MOSFET follower driver oscillation Sheldon Tubes / Valves 19 21st January 2008 08:13 PM
P3A oscillation clive299087 Solid State 22 18th November 2006 11:58 PM
oscillation pjpoes Chip Amps 8 7th October 2005 02:32 PM
mosfet oscillation gustav Solid State 4 9th December 2003 08:46 PM
oscillation 101 Equilibrium Solid State 4 9th January 2003 07:53 AM
Copyright 1999-2017 diyAudio
