Old 9th October 2004, 06:15 PM   #11
larryg is offline larryg  United States
larryg's Avatar
Default thermistor
thanks BobEllis for your reply! i will try the CL 10. if it works you,
it should for me.
larryg
Old 9th October 2004, 06:52 PM   #12
BobEllis's Avatar
you meant CL-30 right?
Also, don't forget a mains rated cap across the switch contacts to take care of the inductive pulse when you turn off. That's what really keeps the switch contacts from burning up.
Old 10th October 2004, 02:34 PM   #13
larryg's Avatar
Default thermistor
yes its the CL 30, i failed to mention that. also will place a xcap
accross the primary[wima fkp1-047 and 600ac]
thank you!
larryg
Old 20th October 2004, 02:45 PM   #14
larryg's Avatar
Default thermistor
the CL 30 works fine! thanks to all who replied!!
larryg
Old 21st October 2004, 12:02 PM   #15
djk is offline djk
djk's Avatar
For a DH220 or Leach of similar size I use a CL-30.
For the DH500 I remove the CL-100 and replace with a CL-60, and replace the 2P relay with a 3P type and have the extra contact short out the CL-60 after the RC time constant.
Old 21st October 2004, 03:40 PM   #16
larryg's Avatar
Default thermistor
hi djk, the CL 30 works good. good to know about the hafler 220
as well for this thermistor. thanks!
larryg
Thermistor help luvtheoldschool Parts 5 4th February 2008 12:56 PM
if an NTC thermistor is rated... jarthel Parts 2 21st May 2007 12:06 AM
how to select an ntc thermistor? jarthel Parts 7 2nd April 2007 10:00 PM
help with ntc thermistor jarthel Parts 4 1st October 2006 04:57 PM
Vbe mult + thermistor rtarbell Solid State 17 2nd August 2006 09:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
