opamp buffers power output q
Old 7th October 2004, 08:16 PM   #1
PederBass is offline PederBass  Sweden
Send a message via ICQ to PederBass
Default opamp buffers power output q
Hi!
Just want to get some input in a question I been thinking about...
What is the relationship between a opamp-buffer's output current vs supply current when looking at it's power dissipation?
Tryin to make my q clearer...If a buffer's data say's :
output current 100 mA
supply current 10 mA
And...PD 1W
Does this means that, with 30v ps, u can take out:
(1W/30v = 33.3 mA
and supply current 10 mA = 33.3 - 10 )= 23.3 mA?
That is u cant take out MORE than 23.3 mA?
Or is there another relationship since one data is DC mA and the other AC mA?
Greatly appreciate any answer...
/Peder
Old 7th October 2004, 08:28 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
Supply current of 10 mA is with no load.
Output current (up to 100mA) is added to supply current in appropriate supply lead (+V or -V).
Pd will depend not only on load current, but supply voltage and output voltage as well. Power dissipation also depends on output stage class of operation, we can assume class B/AB.
Old 7th October 2004, 09:00 PM   #3
PMA's Avatar
Please also have a look at maximum power dissipation vs. temperature and package type.
For BUF634 in TO-220, max. allowed power dissipation is 2W without heatsink (free air). With infinite heatsink, maximum allowed power dissipation increases to 9W ! This says that reasonable heatsink may increase Pd considerably.
Old 8th October 2004, 10:32 PM   #4
Thanx PMA!
Guess that confirmed what I was into..I think..
anyway thnx..
/Peder
opamp buffers power output qHide this!Advertise here!
Opamp output resistor.. jethdub Chip Amps 3 21st January 2008 04:46 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 11:49 AM
Delayed power up when using buffers Nuuk Chip Amps 17 14th September 2004 07:06 AM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
Over-current protection in Audio IC Output Buffers ppl Solid State 1 21st October 2003 07:35 AM
