Old 7th October 2004, 12:02 PM   #1
led_zeppelin's Avatar
Default Newby Esp P67 Question Help Pls!
Hi, i'm building an active pa system (subs and tops) with lynx poweramps from acd, and want to whack in a limiter so i cant melt them!
I use a peavey cs400x (300w per side) and it uses a ddt limiter... Ok, when using full range and a heavy bass note hits it you loose all the top end, but with active xovers as i use (and will build into my project) it works very well.
I found the esp version, and to be fair i dont have a clue... i get the general idea, but i dont know what to do with the control voltage... Do you feed the signal in? or set a threshold voltage? i really don't know.
Also if anyone knows of any better ideas? better designs, maybe even the ddt, i would be very grateful for your input!!
Thank you again...
Matt
DIY, The only way to do it.
newby phase question b1gn1g3 Full Range 3 4th September 2008 02:51 PM
Newby's question about dual coil driver with plate amp minye Subwoofers 6 6th September 2007 08:13 AM
Newby question Peerless XLS12 designs Glen1 Subwoofers 5 22nd November 2005 07:23 PM
Hi, newby here! rolfy72 Introductions 3 11th February 2002 06:43 AM
Page generated in 0.07124 seconds (59.87% PHP - 40.13% MySQL) with 10 queries
