hey guys, while i build my pass bosoz, im wanting to build a passive pre-amp for the time being, but im wondering what pot value should i use? i found a cheap allen-bradley stereo 50k audio mod pot for like $1. i tried it out, but it doesnt go very quiet. even at minimum volume, its pretty loud.
should i do like a 100k or 250k, or should i just put a resistor in line with the pot? thanks guys! |
#2 | |
se |
#3 |
hum, maybe it is wrong.
haha, i did forget to connect the grounds together. the input and output grounds arent connected together. meaning, the left and rights are connected, but the in and out grounds arent connected, maybe thats it. but, a 50kohm stereo pot should be enough? i have it connected as so: (same for left and right channels of course) left input > pin on pot left output > pin on pot. the resistance across these pins, when the volume knob is all the way down measures 50kohms, as i turn it "up", the resistance goes down. so, as i have it wired, im subtracting resistance from the input to output rca's as i turn it up. i "think" thats right. at least it seems valid in my stupid little head. but i want to at least know if that pot will work ok. |
#4 |
Hi cowrang
Your pot has three terminals. Looking at it from the shaft end with the terminals upward, signal in goes to left terminal, signal out comes from center terminal, ground (both in & out) goes to right terminal. Cheers Rob |
#5 |
Hi Cowanrg
Sorry for misspelling your handle. I sometimes suffer from dis lexia or dat chardonay or.... Cheers Rob |
#6 | |||
Ultimately you need to strike a balance between the load impedance seen by your source component(s) and the output impedance from the pot. 50k will work, but will have a higher output impedance than say a 10k pot. So if you're not locked into using a 50k pot, a 10k pot would give you a lower output impedance and is a load even most tube sources can handle. Quote:
se |
#7 |
Have a look at figure 5 on this link. http://sound.westhost.com/pots.htm
The paragraph above the picture has the wiring details. Cheers |
#8 |
perfect!
ill give that a try today and get back to you. |
#9 |
seems like it worked. however, the channels arent matched perfectly. it was a dual-concentric pot though, so i just got a knob that works both left and right separately. works fine for now. however, with my low-efficiency speakers, i do need gain. however, this isnt for me, and that person has higher efficiency speakers, so it should work fine for the time-being. thanks guys!
| Passive Crossover for Passive Subwoofer? | Toast_Master | Subwoofers | 23 | 30th April 2006 12:14 AM |
| passive pre amp | mschwilson | Solid State | 10 | 27th July 2005 01:43 PM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| Help with passive pre | sejarzo | Everything Else | 9 | 27th April 2004 06:11 PM |
| Passive EQ? | Johan_Ch | Everything Else | 1 | 4th September 2003 04:11 AM |
| Page generated in 0.11034 seconds (82.69% PHP - 17.31% MySQL) with 10 queries |
