Old 6th October 2004, 01:55 AM   #1
Default class B and AB idle current
would anyone be able to explain to me what the idle current for class b and ab are??...i understand that for class a it is 1/2 of Ipeak..how do you calculate for b and ab??...any help would be appreciated
Old 6th October 2004, 03:17 AM   #2
wolver is offline wolver  China
Class AB is 5~20mA(Ie) from experience......
Old 6th October 2004, 03:37 AM   #3
Enzo is offline Enzo  United States
The simple answer is that you want to bias the output devices on just enough to eliminate the crossover distortion.
Old 6th October 2004, 03:53 AM   #4
sam9 is offline sam9  United States
sam9's Avatar
D. Self has done some work which seems to say that the voltage across the Vbe multiplier is what should be measured for least crossover distortion rather than current. ~2.89V for a EF output stage and 1.29V for aCFB configuration.
Of course the best solution, not available to many DIYers is to adjust it for minimal distortion.
Old 6th October 2004, 03:58 AM   #5
Mr Evil is offline Mr Evil  United Kingdom
For class B, quiescent current is ideally 0, but in reality will be bsomething very small. Class AB is anything greater than class , but less than the maximum peak load current. More than that is class A.
You should note that the optimum bias current for minimum distortion is in class B, just below class AB. i.e. you should set the bias as high as possible without the devices conducting significantly. The reason for this is well described here.
https://mrevil.asvachin.eu/
Old 6th October 2004, 04:32 AM   #6
It has been found by myself, that running as much current as possible without overheating is usually the best. If you want to get the best transisiton between class A and class B, which almost always is necessary, then with output bipolar transistors, drop 15mV-22mV across any emitter resistors. This is a good first approximation.
Old 6th October 2004, 05:14 AM   #7
thanx for your help guys
Idle current adjustment for NAD gvelim Solid State 0 5th August 2008 03:56 AM
nad 3020b idle current reddish75 Solid State 4 4th July 2008 02:46 PM
JL AUDIO 250/1 idle current Pioneer621 Car Audio 2 24th April 2008 10:31 PM
chip amp idle current maylar Chip Amps 2 29th December 2004 03:25 PM
XM-1502SX Idle Current sdoom Solid State 1 9th July 2004 07:35 AM
Page generated in 0.10095 seconds (76.48% PHP - 23.52% MySQL) with 10 queries
