i have a old amp with upper Volt 12V to 25V + -
it is work it LM555. where can i find this schmetic....... to build a car amp power supply with LM555 thanks tamir |
#2 |
It will be a switch mode supply using the 555 as a crude Pulsewidth Modulator (PWM). If you look on Google you will probably find quite a few schematics of this kind.
Better though would be to build a switch mode supply on a better chipset, if chips are difficult to get in your country look to the TL494 as they are common in PC power supplies (I have several of them from otherwise dead PC psu's |
#3 |
The 3842 / 3843 family is available from lots of manufacturers all over the world at low cost. It's a very easy chip to use with plenty of helpful app-notes, and ideal for stepping 12V up to 25v.
#4 |
thanks all
| Car Amplifier Power Supply | Perry Babin | Car Audio | 47 | 27th January 2008 07:45 PM |
| Power supply for Heathkit WA-P2 pre-amplifier | ghola | Tubes / Valves | 4 | 29th December 2006 02:04 PM |
| Amplifier power supply test-bed | jackinnj | Solid State | 0 | 7th July 2004 09:19 PM |
| Amplifier power supply question: | K-amps | Solid State | 37 | 4th December 2003 12:47 PM |
| Page generated in 0.06440 seconds (70.94% PHP - 29.06% MySQL) with 10 queries |
