Old 14th October 2012, 02:38 AM   #221
Tony is offline Tony  Philippines
Tony's Avatar
welcome......
why not post in the swap meet when you get your pictures ready? just a heads up....
Old 14th October 2012, 02:56 AM   #222
Thanks for the welcome and the heads up regarding the "swap meet". I'll check that out.
Old 14th October 2012, 03:10 AM   #223
Tony's Avatar
no problemo...if you have some tips as to how to repair these tiger beasts, that will be most welcome.....i still have some 8pcs 40409 but just one 40410? would you happen to have some stocks left? or know where i can get them? thanks...
Old 14th October 2012, 03:05 PM   #224
Here's the last 3 of some on Ebay:
Lot of 3 RCA 40410 70 Watt AB Amp Driver New | eBay
Old 14th October 2012, 06:58 PM   #225
expert in tautology
bear's Avatar
I have not looked into it, but it seems silly to use the old 40409/10 combination today. It looks like they are merely lower power TO-5 cans on a heatsink, and not a higher power die... I think that if I get back to them, I'll look for complimentary devices with similar hfe & ft with a modern package but higher power and heatsink it.
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 17th October 2012, 02:34 AM   #226
I agree, but the OP wanted some. It escapes me at the moment, but I seem to remember a newer replacement that would operated without the need of an integral heat sink. Many commercial amps just use a higher power drive in a larger case such as the Sony STR-7065 I'm working on now. Ordering caps from Mouser because it has some noise on the right channel and also it's almost as old as the UT.
Old 17th October 2012, 03:08 AM   #227
Tony's Avatar
thanks, i just wanted to even out my stocks...for future projects...
Old 17th October 2012, 03:09 AM   #228
Tony's Avatar
_-_-bear
you are correct, some of us diy'ers can have silly ideas at times.... ...and crazy too....
Old 17th October 2012, 03:26 AM   #229
wrenchone's Avatar
You could do lots better with some Fairchild TO-126 driver XSTRs readily available from Mouser. I have some 40409s and 40410s in my parts bin - they may sit there until doomsday, or maybe they're keepsakes back from the time that RCA had a semiconductor division, back before the RCA-GE-Harris-Intersil cluster****. I don't even bother to keep track anymore, though the whole mess seems to have gelled around Intersil for the time being.
Old 4th December 2012, 03:23 AM   #230
Just a few photos of mine. My father bought most of the parts for this back in '71 after the article came out. Still have the original magazine. He didn't build it until around 1986-87. Metal shop at General Motors made the case and cover. Had to replace the switch today so I took some pics of it. Just happened to google the amp and found this page...
-Michael
Swtpc Universal Tiger Improved And Simulation PB2 Solid State 91 3rd June 2011 06:50 PM
Tiger 207\A Formosa Parts 1 4th April 2009 02:08 PM
SWTP Universal Tiger help: works, but very low power kevinabb Solid State 4 31st January 2008 05:45 AM
Tiger Amp Boss_Ronald Solid State 1 16th January 2008 07:26 PM
SWTPC Universal Tiger 100 Allen Bartee Solid State 3 26th April 2005 04:10 AM
Copyright ©1999-2013 diyAudio
