N-Fdbk Question
N-Fdbk Question
Old 2nd October 2004, 07:49 PM   #1
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Default N-Fdbk Question
Without getting into a major discussion of Negative feedback...
I have been studying the Soundcraftsmen Amplifier design for sometime now. I have owned and repaired quite a few of these little amps like the PCR-800 and Pro-Power 4.
Soundcraftmen uses this same design for at least 10 different amplifier models. it is a simple design that i was once told was striaght out of the RCA transistor handbook.
The only differences between the models is a change in 2 of the componets in the neg feedback path and either 2 pairs or 3 pairs of mos-fets between the models designated between hom and semi-pro use.
I dont have a way to post the schematic, but i can email it to anyone interested.
In the Negative feedback path for the home amps they use a 1,600 ohm resistor inline between the speaker output and the 2nd Transistor of the differential pair and a 16K ohm resistor and 220uf cap to ground.
the pro models use a 680 ohm and 22K ohm resistors respectivly.
I would imagine they would do this to make the pro amp more stable??? one having more neg feedback then the other???
Can anyone offer any insights as to what changes occur by changing these 2 resistors?
Zero
Old 2nd October 2004, 07:57 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
Default Re: N-Fdbk Question
Probably opposite resistor manner. The voltage gain would be about 20dB.
The voltage gain is 30dB now.
Simple answers written in italics.
Old 2nd October 2004, 08:01 PM   #3
Zero Cool's Avatar
Oops, your exactly right i got the values backwards.
Home 16K inline and 1.6 to 220uf to ground
Pro 22K Inline and 680 to 220uf to ground
Zero
Old 2nd October 2004, 08:03 PM   #4
Zero Cool's Avatar
So its just sensitivity it changes! I see, does the bandwidth stay the same etc?
Old 3rd October 2004, 10:45 AM   #5
R.I.P.
Hi, the lo frequency time constant is different; 352mS and 150mS. The low end will start to roll off and the phase angle will start to become significant at about 5Hz and 12Hz. both these values are probably O.K. for bass speakers. For a very low frequency sub-base you could try changing the 150mS time constant. It may show some difference when you try other values. Worth experimenting.
Do any others have info/experience on setting this RC time constant?
Old 3rd October 2004, 11:08 AM   #6
PMA's Avatar
I am usually setting the low frequency -3dB corner at 2 - 3 Hz.
Old 3rd October 2004, 05:29 PM   #7
Zero Cool's Avatar
Thank You everyone!!!!!
Old 3rd October 2004, 07:31 PM   #8
Jocko Homo is offline Jocko Homo  United States
Banned
The HF will start to roll-off a bit faster in the higher gain one.
Jocko
N-Fdbk QuestionHide this!Advertise here!
do i REALLY need a crossover?? and an amp question. and an ohm question legendaryfrog Multi-Way 4 29th October 2006 01:39 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Parts 14 12th January 2004 02:23 AM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
