Old 28th June 2002, 02:45 AM   #31
Default e96mlo
I thought the point we were discussing was the suitability of transistors as low voltage high current devices, therefore needing low impedance speakers. I have shown you that they exist, So is it more rewarding to pursue this line of enquiry?I'm not an engineer so I don't have the anwser's. I repeat, the auto guys seem to do just fine with 12 volts
RW
Old 28th June 2002, 02:50 AM   #32
Warp Engineer
On Holiday
AudioFreak's Avatar
The auto people also make extensive use of SMPS DC-DC converters to get suitably high rail voltages.
Old 28th June 2002, 02:54 AM   #33
Yeah but with devices like the 2N5686/5684, you'd think that low impedance would be quite an option.
- "With power amplifiers, negative feedback is a good thing, and positive feedback can induce destructive oscillation, but with people, positive feedback is a good thing, and negative feedback can induce destructive oscillation"
Old 28th June 2002, 03:22 AM   #34
Default high cuurent
I guess the things that come into play are manufacturing costs,bigger current bigger transformer's etc etc. So theory has to make way for the practical
RW
Old 28th June 2002, 04:01 AM   #35
Circlotron's Avatar
Wink NOW the truth comes out...
Originally posted by Duo
I wanted to use some parts lying around to make an amp capable of breaking windows and lightbulbs making the neighbors go looney while their dishes fall out of the cupboards (which actually did happen once and I could get other people to justify that... heehee
Aha!! So it was YOU that was cranking up the watts in your cabin to the extent that it made the Titanic sink. I remember the dishes part...
“Ideal” power/regulation for higher-current digital-section ICs hollowman Digital Source 0 8th April 2008 04:07 AM
Higher power amps using 807's or 1625's frank754 Tubes / Valves 59 13th August 2007 07:46 AM
Is PFC needed for higher power amps? Jan Volkering Solid State 12 23rd April 2007 05:37 PM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 06:40 AM
Page generated in 0.09197 seconds (73.58% PHP - 26.42% MySQL) with 10 queries
