Old 27th September 2004, 11:20 AM   #1
Zombie is offline Zombie  Sweden
Default Two zeners to ground in audio input?
What is that good for?
Two zeners in series to ground on each channel, one pointing to ground, the other to the signal...there's a resistor to ground, too and the usual input cap...
Tom
Old 27th September 2004, 11:27 AM   #2
Mr Evil is offline Mr Evil  United Kingdom
They limit the magnitude of the input signal, most likely to prevent the amplifier from clipping, maybe because it behaves badly when it does, or to soften the clipping characteristics.
https://mrevil.asvachin.eu/
Old 27th September 2004, 12:08 PM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
it can also serve as ESD protection. static discharge will be routed to ground.
Old 27th September 2004, 12:26 PM   #4
Hello!
I might be the ESD, yes. The input goes to a 4066 solid state CMOS switch.
How does it affect the sound? Not at all?
Thomas
Old 27th September 2004, 12:39 PM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Zeners show non-linear capacitances high enough to affect high frequencies if source impedance is not very low
In order to clamp low level signals, zeners should be used only as continuously polarized voltage references, not directly as clamp elements, since the capacitance of the zeners by itself may be enough to unexpectedly clamp the signal while it gets charged
Thus, a much better aproach is generating a positive and a negative references through a zener to ground in series with a biasing resistor to the corresponding supply rail, and using 1N4148 diodes to clamp the signal. 1N4148 has much lower capacitance and faster 'switch' than any zener
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
input connection and ground on ucd 180 bcrazy Class D 2 21st March 2007 04:23 PM
how to isolate input ground? Zero Cool Solid State 0 17th December 2006 10:11 PM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
Zeners For Input Question vdi_nenna Pass Labs 4 1st April 2001 07:30 PM
Page generated in 0.07297 seconds (84.60% PHP - 15.40% MySQL) with 10 queries
