Hi diyaudio-folks!
I'm new here and is looking for info on voltage conversion on a Mark Levinson 32 Preamp. I have looked with the search command but cannot find anything so I ask you instead.
Can I convert a 32 preamp from 110v/60Hz to 220-240v/50Hz with a flick of a switch or is it more complecated then that?
/Joakim
/Joakim
There is a guy in Norway who has bought some ML equipment and converted them from 110v til 230v easily.
Since you are Swedish, maybe you can understand this thread and email that person:
http://www.hifisentralen.no/cgi/yab...hifi1;action=display;num=1080325311;start=0#0
But it seems that it is a difference between some of the ML designs, regading voltage converting.
