Ok, I admit i don't make any sense out of this - diyAudio
Old 26th September 2004, 02:03 PM   #1
analog_sa's Avatar
Default Ok, I admit i don't make any sense out of this
PD was recently kind to post a fragment of the ML38 schematic.
For the last couple of hours i've been staring at the PS arrangement and feeling very dumb. Power to the collectors of the matched transistors seems to be supplied on both sides from CCS feeding a unity gain opamp. What's the point?
Old 26th September 2004, 02:47 PM   #2
jan.didden's Avatar
Frank,
Very strange indeed. Could there be a drawing error in the interconnection of the terminals of those matched pairs? That doesn't make sense.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 26th September 2004, 02:54 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I'm not sure if you read it right, but the dual transistor is in 8-DIP package, so it is represented by the frame outline on a drawing. The power is supplied to one of the collectors, the other collector is connected to the emiter (of the other transistor).
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th September 2004, 02:59 PM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
This appears to be a funny and exotic way of cascoding
All transistors appear to work at a fixed Vce of about one diode drop
Old 26th September 2004, 03:36 PM   #5
jan.didden's Avatar
But that transistor that has the collector to the emitter of the other, that places its collector-base diode in conduction, isn't it? That would influence the operation of the input, no?
Edit: that collector doesn't appear to get any supply, as it is connected (with the other emitter) directly to the output via 10 ohms.
Jan Didden
Old 26th September 2004, 04:00 PM   #6
Eva's Avatar
Left side transistors work with Vc = Vb so its Vce is one diode drop
Right side transistors work with Vc = Vb + diode drop so its Vce is two diode drops
Note that left side transistors have its bases tied together while right side transistors have its emitters tied together
Note also that small signal transistors may work with Vce as low as 0.1 V [ie: collector potential between base and emitter potential
Redrawing the schematic may help to understand it
Old 26th September 2004, 04:10 PM   #7
Here's the redrawn version. It looks much clearer now.
www.audiosector.com
Old 26th September 2004, 04:56 PM   #8
jan.didden's Avatar
Thanks Peter, that's MUCH better.
Eva, does that mean that the right side transistor works in what looks like bootstrapped common-base?
BTW, who designed this?
Jan Didden
Old 26th September 2004, 04:59 PM   #9
andy_c is offline andy_c  United States
Banned
Default Is this better?
Here's yet another interpretation. It's a diamond buffer with the input collectors bootstrapped to the output emitters, and the output collectors bootstrapped to one diode drop away from their respective bases.
Old 26th September 2004, 05:04 PM   #10
This circuit is used in Mark Levinson ML380 preamp, as well in some other ML units.
Is there a need for dual NPN/PNP transistors here?
www.audiosector.com
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
does this make sense? nosegoblin Solid State 9 14th February 2004 02:19 PM
Does this make sense? Illusus Chip Amps 11 25th September 2003 01:59 PM
Copyright ©1999-2017 diyAudio
