Ok, I admit i don't make any sense out of this
Old 26th September 2004, 06:12 PM   #11
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Re: Is this better?
Originally posted by andy_c
Here's yet another interpretation. [snip]
Neat!
This is a buffer, right? Looks like a lot of work to replace a piece of wire..
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 26th September 2004, 06:14 PM   #12
jan.didden's Avatar
Originally posted by Peter Daniel
This circuit is used in Mark Levinson ML380 preamp, as well in some other ML units.
Is there a need for dual NPN/PNP transistors here?
I think for best results they should all be matched. Difficult without duals or better, quads. The THAT series quad matched transistor come to mind.
Jan Didden
Old 26th September 2004, 06:20 PM   #13
andy_c is offline andy_c  United States
Banned
Default Re: Re: Is this better?
It's a curved wire without gain
Old 26th September 2004, 06:46 PM   #14
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
It's a diamond buffer with the input collectors bootstrapped to the output
After some redrawing i figured that out but what is the purpose of the opamp+current source?
Old 26th September 2004, 06:51 PM   #15
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The current sources force the input transistors to work at a nearly constant Ic
The op-amps work as 'cascodes' and force the output transistors to work at nearly constant Vce
Look how andy_c has redrawn the circuit in a much clear way
Old 26th September 2004, 07:27 PM   #16
Steven is offline Steven  Netherlands
Steven's Avatar
Thanks Andy_c, only after your drawing it was clear to me what the actual design was.
Funny, how one needs to draw a schematic in a certain way to recognize things. People are severely restricted in this compared to Spice.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 26th September 2004, 07:31 PM   #17
ChocoHolic is offline ChocoHolic  Germany
In fact a cool advanced diamond!
Old 26th September 2004, 08:36 PM   #18
analog_sa's Avatar
Many thanks for the explanation Eva.
Old 26th September 2004, 09:00 PM   #19
Banned
Yes, our circuit pattern recognition seems to want to see things in a certain way. I've had circuits I've designed myself put into a CAD system by a draftsman who redrew them in such a way that I could not understand what the circuit was! Curious how the mind works.
Old 7th October 2008, 05:15 AM   #20
Destroyer OS is offline Destroyer OS
Destroyer OS's Avatar
If anyone stills looks at this thread, is it by chance the Borbely style? I am slightly lost, but I have been show this,
http://www.diyaudio.com/forums/attac...amp=1136397897
Ok, I admit i don't make any sense out of thisHide this!Advertise here!
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 7th September 2008 12:35 AM
does this make sense? nosegoblin Solid State 9 14th February 2004 03:19 PM
Does this make sense? Illusus Chip Amps 11 25th September 2003 02:59 PM
Copyright ©1999-2017 diyAudio
