Is it possible to measure amplifier gain using just a digital multimeter? I was thinking to input a constant sine wave, like 100hz, and measure the voltage using the multimeter on ac mode, then measure the output of the amp.
If I can do this, do I need to load the outputs of the amplifier whilst measuring the gain or not? Cheers |
#2 |
Electrons are yellow and more is better!
You can for example take 100 mV in and then you should have 2-3 volt out. You don't have to have a load at those levels and frequencies
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
Cheers, I will give it a go and post the results here.
I am doing it so I can equalise gain in an active speaker with different amps for the bass and mid / tweeter |
#4 |
A digital multimeter will work, but not well for higher frequencies.
#5 |
Hi, Do you know how to build a switched variable attenuator? All you need is a bank of double pole switches and some accurate resistors.
Can anyone out there post a circuit layout? Provide attenuation of -20db,-10db,-5db etc. down to the level you require. Insert this on the input to your amplifier. Set up the switches to give the output level exactly as the input level from an oscillator or even a test disc in a cd player. Since the AC reading multimeter is now comparing the same voltage at input and output it ignores error in frequency response of the multimeter and can be used effectively over a very wide frequency range. I have taken readings upto 150kHz to check the frequency response of a range of power amps. I cannot work @ very low frequency because my multimeter samples the waveform and @ less than 12Hz it becomes very difficult to take sensible readings. |
#6 |
OK, so I measured the input and output voltage, the voltage gain was 20.3, which is near enough 26db
I want to take 6db off this, so I figured an attenuator circuit 10k in series with signal and 10k to ground after this would do the job. This will then equalise my Nakamichi PA7 (26db of gain) with my Pass Labs Aleph 3's (20db of gain) .... I think! |
| Measuring an amplifier with my humble devices | pjpoes | Solid State | 7 | 4th July 2008 02:20 AM |
| Bruel & Kjaer 2609 Measuring Amplifier | Fanuc | Swap Meet | 0 | 1st April 2007 12:24 AM |
| amplifier gain | djdamix | Solid State | 3 | 25th September 2004 07:03 PM |
| Low openloop gain amplifier | lumanauw | Solid State | 33 | 7th February 2004 05:18 AM |
| measuring Input impedance of an Amplifier | pinkmouse | Solid State | 5 | 23rd May 2002 08:15 PM |
| Page generated in 0.08967 seconds (76.44% PHP - 23.56% MySQL) with 10 queries |
