Yeah... i'm building an active pa system ofr my a level project, consisting of a pair of mid hi's (some old peaveys i have) and some subs (modified rog's X1 (with a 15inch kappa)), all powered by 4 lynx poweramps from acd with 4 625va transfo's 45-0-45. MMMMMMmmmmm....
In these boxes will be a PCM2409 (not sure if thats the part number) usb soundcard with spdif, and active crossovers. and microcontroller temp control of fans... Basically i'm a bit unsure of the crossover... i've designed this one, but i haven't got any decent simulation software, not to mention dont know what i'm doing! basically i want it to cross at around 150hz (if anyone knows a freq that would sound better i'd gladly use that) and also, i would like it to be variable... as in a pot to change the xover point.... Pls could i have your advice/opinions... All help as usual is much appreciated!! Cheers Matt edit... and in the pic, why are the two out's out of phase?
DIY, The only way to do it. |
#2 |
Basically, i could do with an idea of the freq to volume graph? to 'see' the crossover and ideas as how to make it variable? cus there's many components id need to change at once i'd think?
#3 |
#4 | |
You can use Texas Instruments "Filter Pro" software -- freeware and it works quite well. It can be downloaded from their website, just plug FilterPro into their search engine. |
#5 |
try the ESP website man...rod has a comprehensive article on active filters...also the headwize site is a good read
#6 |
Basically these are two cascaded Sallen-Key active stages to end up with a 4th order filter + buffer with variable gain for each channel. However, with the component values given these will NOT give a standard Butterworth (thus an overall Linkwitz-Riley) response for each stage. Look at the Texas Intstruments website under FilterPro for appropriate component values.
If these were indeed L-R filters, the two outputs would be in phase at the crossover frequency. Having a variable crossover frequency with this circuit is quite a mess as you would need a 4-gang pot (8-gang for stereo). You could simulate this circuit with PSpice Student which AFAIK could be downloaded for free. /Magnus
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction |
#7 |
First of all, a capacitor will create a phase shift. I would say that just one 40dB/dec filter would be sufficient. May save parts.
You could always add a series capacitor to one filter to create a phase shift in order to make the two have the same phase shift. Seems fairly simple to me. However, the phase shift may be different depending on the frequency so the bandwidth couldn't be to large. |
#8 |
Elektor has published an article with the entire plans for a 2 Way linear phase crossover. Here is the link for a correct copy : http://users.otenet.gr/~athsam/2way_...near_phase.htm Hope it helps ! Regards. Moncef Christian Mentagui |
#9 | |
/M
| WTB: 2 way active xover | MarkHathaway | Swap Meet | 0 | 21st September 2008 09:31 AM |
| Behringer DCX2496 I want to try active biamping using it as the active xover. | georgehifi | Digital Line Level | 3 | 15th August 2006 07:46 AM |
| active AD/DA xover as RIAA-amp? | miksin | Digital Source | 14 | 15th July 2005 12:43 AM |
| active xover | 5th element | Solid State | 0 | 9th March 2003 07:19 PM |
| ACTIVE XOVER | KIERANPHILLIPS | Solid State | 4 | 20th August 2001 07:29 PM |
| Page generated in 0.08895 seconds (85.92% PHP - 14.08% MySQL) with 11 queries |
