As several people on this thread seem to use or know a little of ORCAD, can anyone tell me if it's possible to import an ORCAD DOS design from the past (version 3.10) onto a newer one (version 9.0). Which are the steps?
Thanks! Carlos |
#2 |
Convert the old ORCAD into a DXF file. Then import into the new one.
#3 |
Fidling with layout:
Designing a new amp board wich will act as upgrade board (for Tandberg 3006A).As it consist of bouth smd and "normal" components. How can i set some of the smd's on bouth sides as prefered, also Top and bottom komponents to overlap? As this will 'solve all my problems' |
#4 |
Konrad:
Have you checked the components outline ? If its set to global and not restricted to one side you will have an Design Rule Check violation. Sometimes ORCAD don't seems to understand that you want to place on both sides |
#5 |
carlmart...
Are you importing the whole project, with schematics, or just the layout?? In principle , you should be able to import directly, but be prepared to run the library manager parallell, as you might have to define all teh footprints again. There is also an import function if your old file is an ASCII netlist or MAX file. There is no reference in the manuals or help files to the older versions. Konrad: In component mode, mark the comp. in question, - right click and "opposite" ( Shorthand - "T") ( you should see the footprint change colour according to the top/bottom layer colour ) BTW-Konrad..how far north ?? |
#6 |
Macyver, Aurora Borealis: tanks reply, just the input i was lookig for.
OT: Aurora B : about placement |
#7 |
Andøya ....
Drop me a mail, - ---- since yours is disabled! |
| OrCAD libraries | AuroraB | Parts | 3 | 14th February 2007 08:15 AM |
| does anyone know how to add a transformer in orcad capture? | jarthel | Power Supplies | 2 | 14th August 2006 01:10 AM |
| Orcad & tube library | Antonix | Tubes / Valves | 3 | 26th December 2005 02:54 PM |
| OrCad 9.2.3 Purchase Advice | Frazzled | Everything Else | 3 | 8th September 2004 03:52 AM |
| OrCAD 10.0 Demo | jcx | Parts | 0 | 20th February 2004 06:07 AM |
| Page generated in 0.09570 seconds (75.31% PHP - 24.69% MySQL) with 10 queries |
